Sponsored by: CARiD
what to do with this tire???
Old Jan 28, 2009 | 08:00 PM
89needsatranny's Avatar
so i bought a set of used wheels and tires last week and am getting ready to put them on.
the tires are bfgoodrich A/Ts and 2 of them have a little bit more wear on
them than the other 2. One of the more worn ones has an eneven wear on
the right side of the tire. So my question is where should i put the uneven
one on?(which tire where?)
ask questions if i didnt give enough info or i will put up a pic of the tire if you
want.
thanks alot!!
Old Jan 28, 2009 | 08:10 PM
crolison's Avatar
if you need a spare and they are 16's (265/75/16) i have a few for spares, pm me if interested.
Old Jan 28, 2009 | 08:13 PM
Ardent's Avatar
Uneven one should be on the rear as to not mess with your alignment. It should even out eventually. My understanding is that you should try to pair the different wear amounts across from each other. i.e. The two with the most tread up front, the two with less on the rear.
Someone else might have advice that's more better () than mine.
Old Jan 28, 2009 | 08:16 PM
91TPU's Avatar
i say put it on the back, i would think unevenly worn tires would wear better on the rear then on the front and if mounted in front they may cause steering vibration
Old Jan 29, 2009 | 02:26 PM
okay thanks alot, all of you!!
1uzRunner
63
Nov 10, 2018 03:58 PM
Williamemslie
14
Oct 5, 2015 09:28 AM
AkitaDog
Sep 3, 2015 09:01 PM
128keaton
Sep 3, 2015 05:09 PM
matthew138
Sep 3, 2015 08:21 AM
