Roaring sound from Newly install Third Member
So I put a new 3rd in my rear end and it was in touched came from a friends truck now its makin a roaring sound and its completely full with fluid it doesn't make an sense to me can some one tell me what's goin on
I am confused by the 'in touched came from a friends'? it was pulled from your friends truck?
If it was used, it sounds like the bearings are crap...if it was brand new someone did not set it up correctly and probably has too much preload...
fixing your thread title 'Little Help Please' can lead to deletion by the rules, make it more specific to your issue
Ok sorry about that it was un touched he drove it till about 2 weeks ago un till a guy hit him in the front the reason I got it is because the one I had needed bearings
http://www.gearinstalls.com/index.htm
James
If it didnt make any nosie for two weeks you have a bend axel thats y your other bearing burnt up it done the same to the new 1. My brother had the same problem went through 3 3rd members before we found out the problem.
Just talked to my brother he said you just need to replace the whole rear end unbolt it from the leaf springs and put a new or used 1 in. He said hes 99.9% forsure
Say huh? Ummm, who's your brother? Put him on the horn....or explain this to him for me would ya?
You're saying a bent axleshaft burnt up a carrier bearing in the 3rd member?
They aren't connected in any way to each other. The axleshaft, for lack of a better word, plugs into the side-gear. It never touches any other part of the 3rd member.
REPLACE THE WHOLE REAREND???
Dude, let's just forget you said that. Have we been?
My brother said he replaced passengers side axel and the 3rd member and never had a problem again the guy that brought the truck from him still hasnt had any problems from the rear end. Before replaceing the axel and that 3rd he burnt up 3 previous 3rd members in a two month period and all 3rds was in great operating condition.(This repair was done 3 years ago) If the driveshaft is bent that could be a possible issue.
Mud hippy the spider gears and ring gear ride on the carrier bearing rite? The axelshaft connects into the side of the spiders if an axel is bent causeing the whole assybly to move other than were its pose to be moveing will cause wear on the carrier bearings rite? If im incorrect would somebody please chime in and explain to me how it works
Man i aint an expert but i would think anything that could make anything vaibrate in there would cause damage. Did your do any thing besides take the 3rd out of your buddys truck and install in yours?
You'd feel it vibrating if it were out of balance. And it would take A LONG time before it would do any damage(if ever). Unless it was shaking so hard it rattled your teeth.
Mud hippy i aint sayn your wrong and im right, or your right and im wrong, Im just sayn that after going through 3 3rd members the bent axel was found and changed with the 4th 3rd member and there wasnt anymore trouble out of it even to this day the guy that bought the truck drives it with no problems what so ever outa the rear end.
