Sponsored by: CARiD
sas without high steer
Old Jun 30, 2011 | 05:15 PM
ding's Avatar
Ok so Ive looked on a couple other sites looking for an answer and still haven't gotten anything difinative. I have and 86 4runner and am planning a sas. I dont have a lot of money to do this with. I also have a complete 81 pickup minus the motor. Im just curious if I can do the sas with Skys sas bracket kit and not have to use a high steer conversion. Im not planning a big lift only 3 or 4 inches. Just enough to clear my 33s (yes 33x10.50s fit on a stock 4runner. they just rub). Does anyone know for sure? Im about ready to just try it and hope it works.
Old Jun 30, 2011 | 05:18 PM
SCToy's Avatar
Not possible, your IFS box has rotates on the wrong axis. It would be more work than it's worth to save the money. Look for someone selling a hi-steer kit used. That's what i did. I actually got them used, but new. Someone scrapped a project before it ever got off the ground.
Old Jun 30, 2011 | 07:00 PM
James Woods's Avatar
If you don't have a lot of money to do an SAS right now, then maybe you should save up and do it later. I already have about $400 into just the axle so far and am still far from done, don't spend all that time doing the swap just to have to pull stuff back off to fix the corners you cut.
Old Jun 30, 2011 | 07:01 PM
4Crawler's Avatar
Was done in the early days. Used to be a writeup floating around about 14 yrs. ago with pictures about that very swap:
- http://web.archive.org/web/199706070...t/projtoy.html
You'll need to adapt the push-pull steering to the IFS frame, and since nobody makes kits for that, you'll need to fab. brackets, etc. Plus set up the torque rod upper mount. Probably looking at about the same amount of work as the SAS and then if you do go to crossover steering, you'll need to do about that much more work to swap the steering over.
Some other options below:
- http://www.pirate4x4.com/forum/archi...hp/t-2827.html
Bottom of that page.
Old Jul 1, 2011 | 04:50 AM
waskillywabbit's Avatar
Some things that are doable shouldn't be done.
Save your money and time and do a proper high steer. Worth the money and wait.
:wabbit2:
Old Jul 1, 2011 | 08:14 AM
ZUK's Avatar
ZUK
Low cost....free....How about basic cross-over?
The long tie-rod stays UNDER the leafpacks and the long draglink is ABOVE the leafs and goes all the way over to the passengerside modified steering arm....follow this link
http://board.marlincrawler.com/index...3545#msg833545
Old Jul 1, 2011 | 08:44 AM
4Crawler's Avatar
I initially put on the original AllPro crossover steering kit on my '85, had a stock drv. side arm (J-end cut off) and a fabricated double steering arm on the passenger side and a modified pitman arm set up for heim joints:
Flying91
45
Apr 11, 2024 04:39 PM
delmert
Sep 30, 2015 04:34 PM
priest16
15
Aug 6, 2015 07:43 AM
Shaun Crystal Gomban
Aug 2, 2015 08:00 PM
tomczaksdiesel
Jul 26, 2015 10:35 PM
