Sponsored by: CARiD
to much negative offset
Old Jul 6, 2011 | 12:13 PM
F00PDA3W00P's Avatar
now my question is i have an 88 lifted 6 inchs and have 35s on with 410s ok ifs up front and i rub on upper A's can i put the 1.25" spacers on front to make the clearance i need
Old Jul 6, 2011 | 01:30 PM
MudHippy's Avatar
I'd say there's a high percentage chance it'll work. A good way to test out the hypothesis would be to put the front of the truck on jack stands. Then loosen a wheel by removing the lugnuts by 1" or so. Steer the tires to the points where they make contact and see where you're at. That's what would do. But with 3.5" backspacing 15x10s my 35x12.5s don't rub nothing steering/suspension wise(almost the idler arm turning hard left though...but by roughly a hair's breadth does the pass side tire not touch it...call it ~3-5mm).
Old Jul 6, 2011 | 01:36 PM
well i put them on and the tires rubbed on upper a's bad so i figured i would just put spacers on oh tire size is 35 12.50 16
Old Jul 6, 2011 | 01:44 PM
MudHippy's Avatar
Right, so no hydraulic jack and jack stands then.
35 12.50 16? Odd...who runs those? Beats me!
Good luck!
Old Jul 6, 2011 | 02:15 PM
sorry 315/75/16
Old Jul 6, 2011 | 02:53 PM
BoredOutnJackdUp's Avatar
I had 35x15.5 boggers on my 83 and they rubbed on my leaf springs. so i threw some 2 inch wheel spacers on it they worked like a dream. didnt have a problem.
but if your worried about it not being enough get a little bigger to be safe.
suppra87
Jul 15, 2021 05:15 PM
Bourbonblues
Dec 15, 2017 05:43 PM
JHalcyonM
Sep 14, 2015 01:10 AM
theduck21
Sep 10, 2015 07:01 PM
kouki420
Sep 2, 2015 11:42 AM
