Sponsored by: CARiD
first time front shocks prerunner
Old May 23, 2011 | 03:04 PM
mole2000's Avatar
Hi- I followed the 'instructions' in my Chilton and on the FSM available here, but I have run into a snag on changing my front shocks on my 1999 prerunner. Supported front control arm and removed the lower mount nut and left the bolt in place; then it says while lowering the control arm, remove the bolt. I tried, but the bolt got stuck partially out. Now its wedged. Is this the need for just a BF hammer? I know there is some pressure there, but wonder just what is going to happen if I slam that bolt out of there. Any advice? Thanks
Old May 23, 2011 | 04:17 PM
DeathCougar's Avatar
Jack the control arm up and level it out. relieve the pressure on the bolt, and it will slide out. If it wont slide out, use a hammer and a punch and pop it out of there but make sure the control arm is supported. Nothing will really happen, other than the arm may drop down a few inches if there is no support there.
Jnkml
Jul 6, 2015 01:20 PM
Vargntucson
Jul 4, 2015 12:15 PM
Niameyrider
Jun 25, 2015 05:50 AM
94 First Responder
May 31, 2002 09:07 PM
