Sponsored by: CARiD
95 T100 Fuel System Diagram
Old Jun 1, 2011 | 06:24 AM
bradstai's Avatar
Hi I am looking for a fuel system diagram, specifically where the two hoses (other than the fuel line) hook up to the fuel tank. I know one is a return line and the other is some type of vent. I recently swapped out the fuel tank and want to make sure I have them right. One comes from the fuel pump bracket and the other from the top of the tank.
1995 Toyota T100, 3.4L, V-6, 4x4, Reg Cab, drivers side fuel tank.
Thanks.
Old Mar 10, 2012 | 02:16 PM
jmbeam's Avatar
How did you make out regarding your T100 fuel tank. Its funny but Im having the same issue however I already hooked mine up and then had fuel spewing all over the place. I was wondering how these lines work. I did some rehab work on this fuel tank and not sure if I screwed up some things.
WOuld this occur if I had the two lines reversed?
Old Oct 17, 2012 | 04:07 PM
'85 Yota's Avatar
I just went through the same problem. I hooked the vent and the return line backwords. That caused the fuel tank to pressurize and caused fuel to pour out the vent. On my 85 the shorter fuel line goes to the farthest hole in the tank.
Old Oct 2, 2016 | 07:49 AM
T100hayes96's Avatar
Where is the fuel pump diagram pictures on this site for a 1996 t100 3.4 sr5
Poppie51
Jul 23, 2015 05:03 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Poppie51
Jul 16, 2015 06:16 PM
jgwerth
Jul 16, 2015 03:23 PM
taller1
Jul 16, 2015 03:00 PM
