Sponsored by: CARiD
injector pulse problem
Old May 23, 2011 | 08:43 AM
mhmacw's Avatar
hello. i was wondering how to check for proper injector pulse signal. i heard you test with key on for 12 volts but shouldnt have 12 volts on both sides? is this true? 1995 3vz thanks, dan
Old May 23, 2011 | 11:55 AM
4Crawler's Avatar
Injectors typically will have 12 volts on both sides, one is the supply power. The other side has 12 volts when the injector is off, then momentarily the ECU will ground the one side of the injectors (0 volts) to turn it on for an instant. A typical volt meter won't catch that quick pulse, so you could use an oscilloscope or a "noid" light that flashes in response to the ground pulse.
Old May 23, 2011 | 12:29 PM
mhmacw's Avatar
thats awesome! 1 less thing on the list of trouble shooting. thanks a bunch!.
Doug4320
Mar 24, 2018 10:11 PM
RatOmeter
Oct 22, 2015 03:17 PM
steve miller
Oct 10, 2015 01:40 AM
Hiluxtrucha
Jul 22, 2015 10:00 AM
karbin
Jul 5, 2015 11:37 PM
