Sponsored by: CARiD
22r coolant flow direction. Help!
Old Jun 17, 2011 | 10:00 AM
goingnowherefast's Avatar
Need help with a flow question.mainly the two steel lines off the rear of the timing cover(drivers and pass side) and the tube off the head in the middle of the intake.Maybe carb only? Thinking the drivers side is a return from the heater box? The head line is the flow to the heater box? The pass side (rear of timing cover) is what?(used to go to the water plate)
I'm installing dual side drafts and they tell me to block off the pass side but want to use the coolant for a old turbo oil cooler.Anyone have an idea how I can run the return line from the cooler back into the water pump.Thinking of a "T" inline but don't want it to flow back into the heater box.
http://i236.photobucket.com/albums/f...3/100_0422.jpg
http://i236.photobucket.com/albums/f...3/100_0435.jpg
http://i236.photobucket.com/albums/f...3/100_0437.jpg
Old Jun 17, 2011 | 10:07 AM
xxxtreme22r's Avatar
Old Jun 17, 2011 | 10:10 AM
ChefYota4x4's Avatar
Wow, cool project. I wish I had a solid answer, but since I do not, I'll sit back and watch and learn while wishing you well! I can say YES, the 22re is much different.
PS> Welcome to Yotatech, GNF!
Old Jun 28, 2011 | 08:00 AM
Thanks, wanted to bump this back up just in case someone had the anwser.I've got a couple oe shut off vavles I can use.The old toyota heater box valve may not close down and hold the heater coolant back so the heat will remain on.
the1998sr5
15
Jul 14, 2020 08:35 PM
JaredL
Mar 28, 2016 09:08 PM
bvleonov
Aug 22, 2015 11:39 PM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
Poncho0206
Jul 10, 2015 06:21 PM
