Sponsored by: CARiD
96 4Runner - swapping rear diffs?
Old Jun 22, 2011 | 05:05 AM
jessem123's Avatar
Question 96 4Runner - swapping rear diffs?
will a 4:11 from an older toyota work in place of the stock 4:10 without blowin up my transfer case when i put it in 4x4
Old Jun 22, 2011 | 05:12 AM
waskillywabbit's Avatar
Welcome to Yotatech
A simple or a search of the forum would answer your question
Moved to Newbie land
:wabbit2:
Old Jun 22, 2011 | 07:22 AM
badattitude's Avatar
Yes, it will
Old Jun 22, 2011 | 07:31 AM
No it might not. Depends on what year is "older" as it could be a 2WD.
:wabbit2:
Old Jun 22, 2011 | 07:41 AM
Listen to wabbit, Also, check the number of bolts on both your diff and the donor diff. Both the current diff and donor diff should have 10 bolts.
Old Jun 22, 2011 | 08:00 AM
jessem123's Avatar
no its not 2wd its from an older front end from an old pick up
Old Jun 22, 2011 | 08:13 AM
dropzone's Avatar
Fossilized
if you are swapping a 4 Cyl into a 6 Cyl, not a great idea...you are losing 2 spider gears.
v-6 Differential is considerably stronger to put up with the 3.4...
Old Jun 22, 2011 | 08:37 AM
blake.nemitz's Avatar
you will be fine with the gear ratios being 4.10 and 4.11 they are the same gears just a rounding deal with the numbers and 1/100 of a difference in ratio can be had with a little more worn tires on the back, so i wouldnt worry about it, and i bet if you count the teeth the same number will be had from both diffs
Old Jun 24, 2011 | 06:39 PM
jessem123's Avatar
well the 4:11 is 9 on the spider and 37 on the crown gear while the 4:10 has 10 on the spider and 41 on the crown
Team420
Jan 12, 2021 04:57 PM
vasinvictor
Jan 20, 2016 12:39 PM
merc1100sc
Jun 26, 2015 05:24 PM
cchinny
Jun 25, 2015 08:11 PM
