Sponsored by: CARiD
Driveshaft go bye bye
Old Jul 11, 2011 | 09:55 PM
4x4jeffyota's Avatar
Well I was on my home from work tonight and I decided to take the interstate. I started feeling a light vibration then a few mins later there was a loud noise then sparks flying from under my truck. I though axle broke or something. Now I need a new drive shaft haha. The sucky part is that there are NO 4x4 Toyota Pickups in any salvage yards around here. Would it be safe to drive it to work until Friday? I drive about 40 miles round trip a day. My wife has a Jeep but I dont want to drive it to work. Even if it does have AC haha. And if anyone has a rear drive shaft for sale cheap let me know. What all years are interchangable? thanks for any help.
Old Jul 11, 2011 | 09:56 PM
All the bolt holes are either broken off or bent to hell
Old Jul 11, 2011 | 10:29 PM
vital22re's Avatar
totally a bro
well you could pull the rear drv line and put in 4wd. I just would avoid the high way in 4wd and keep it limited to emergencies. Just drive the damn heep and get over your pride. We all have to do things we're not proud of to make a living sometimes.
Old Jul 11, 2011 | 11:37 PM
fork's Avatar
ouch.
x2 just drive the heep and park it far away from anywhere your coworkers can see
Old Jul 11, 2011 | 11:44 PM
scuba's Avatar
Next time make sure your drive shaft bolts are all there and torqued properly. I'll put $5 on 1 of the nuts/ bolts worked itself loose and left only 3 to do the job.
Old Jul 12, 2011 | 12:38 AM
vital22re's Avatar
totally a bro
then 2
then 1
then pop goes the driveline!
some lock tite might not be a bad idea.
Old Jul 12, 2011 | 01:42 AM
dropzone's Avatar
Fossilized
Gee seems like I had a similar 'operator head space and timing failure' a couple of years ago...just like Scuba said...
Originally Posted by ocdropzone
I have been driving the '81 around a lot lately since I got it back just because I can.
Anyway yesterday I had a vibration start on the way to work, I thought i would check it out when I got home. Got off work this morning and forgot about it, about halfway home, it was frigging terrible, than thunk at 35 i have to pull over and pick this up and put it in the passenger seat:
it came off at the transfer case end...evidently my head was further up my butt than usual and I forgot to tighten the nuts and bolts
just scraped up a little bit..The Big Guy upstairs was looking out for me as this was morning rush hour.
Pulled it and five minutes later back on the road
Tell you what though driving a locked front end in 2wd it sure pulls a lot on pavement but I got home after a few minute delay but do I feel like the proverbial idiot...
check your work...
Been talking too much smack at work about Jeeps?
Just kidding...
Drive the jeep. You can drive it using the front shaft, if you are locked up front I wouldn't do it.
Parts sources link: https://www.yotatech.com/forums/f116...ts-etc-221646/
Old Jul 12, 2011 | 05:21 AM
xxxtreme22r's Avatar
I think I need to go check all of my driveshaft bolts now.
x2 drive the heep.
Old Jul 12, 2011 | 07:21 AM
toyota4x4907's Avatar
Meeee toooo :\
Old Jul 12, 2011 | 08:17 AM
ScottyC's Avatar
I have some lower section of shafts laying around if you want one. Just cover the shipping.
Old Jul 12, 2011 | 09:48 AM
thanks man, how much would it be shipped to 72315
Old Jul 12, 2011 | 09:51 AM
an uncle of mine replaced my transmission for me about a year ago and he may have forgotten to properly torgue one bolt but idk.
Old Jul 12, 2011 | 06:49 PM
MudHippy's Avatar
For future reference. Car-Part.com.
Searched AR for 1986 Toyota Truck (except T100 & Tundra) Rear Drive Shaft 4x4 SWB MT w/o turbo:
$100 Strop Auto Sales and Salvage USA-AR(Osceola) 1-800-262-7970
$125 Barefield's Auto Salvage USA-AR(Russellville) 1-800-748-8811
Or you can use just the part he has. So long as the bolt hole pattern matches yours.
Old Jul 12, 2011 | 07:09 PM
87hillbillyoter's Avatar
same thing happened to me, driving along, big vibration, then BOOM! rear shaft popped off the tcase, slammed the cab and put a dent in the bottom of it. got a whole new rear shaft. lesson learned haha
Old Jul 12, 2011 | 08:25 PM
85gijunk4x4's Avatar
ouch. i stripped one on my rear shaft (dont ask, long story) doing my twin stick, torqued them, and figured i'd be good driving with 3....GUESS NOT
Old Jul 12, 2011 | 08:55 PM
thanks for the link, I work in Osceola, if I have to I'll buy that one
Old Jul 12, 2011 | 08:58 PM
haha damn.
Old Jul 26, 2011 | 09:05 AM
ScottyC sent me a replacement section for my driveshaft. now all I need are 4 bolts. Would it be fine if I just used grade 8 bolts? Or is there a place where I can order some cheap ones?
Old Jul 26, 2011 | 09:11 AM
ScottyC's Avatar
Driveshaft bolts are hardened metric bolts. Go to the dealer. They should have them.
Also, make sure to have that shaft "in phase" when you put it back together. Its very important.
http://jniolon.clubfte.com/driveline...nephasing.html
4Crawler's Avatar
You can get new ones from Toyota, they are not all that expensive. I might have some used nuts/bolts from mine if you can't find any locally.
