Sponsored by: CARiD
3.0 idle speed ?
Old Jul 8, 2011 | 08:34 AM
BOGDOG's Avatar
3.0 idle speed ?
I finally got back to my 89 3.0 4Runner project. I fired it up and it is idling at about 1300RPM. It stays the same. The engine is equipped with headers, cat back exhaust & a Downey air intake setup. There doesn't seem to be any intake or exhaust leaks. Engine is supposedly a dealer installed factory replacement. Any ideas on what could cause such high idle speeds?
Old Jul 8, 2011 | 11:03 AM
MudHippy's Avatar
It idled fine, now it suddenly doesn't? Correct?
Then here's what the FSM checklist says:
  1. Accelerator Pedal Link
  2. Dash Pot
  3. ?(missing from the list)
  4. Engine Coolant Temp Sensor Circuit
  5. Idle Speed Control Valve
  6. Intake Air Temp. Sensor Circuit
  7. Throttle Position Sensor Circuit
  8. A/C Signal Circuit
  9. PNP(Park/Neutral Position Switch)Signal Circuit
  10. Injectors
  11. Cold Start System
  12. Engine Control Module
http://personal.utulsa.edu/~nathan-b...63troubles.pdf
http://personal.utulsa.edu/~nathan-buchanan/93fsm/
Old Jul 8, 2011 | 02:06 PM
greencactus3's Avatar
mine ended up being the intake plenum gasket
Old Jul 8, 2011 | 02:35 PM
BOGDOG's Avatar
  2. Dash Pot
  10. Injectors
I won't say suddenly because it hasn't been run in a year, but when I bought it it idled fine. I will start on your list. Thanks
Charecter1
Nov 6, 2023 10:08 AM
XtraCab
Apr 12, 2020 05:25 AM
BeMiceElf
Oct 10, 2015 09:40 PM
Alex Bessinger
Aug 31, 2015 09:17 AM
kyletbert
Jul 17, 2015 11:39 AM
