Sponsored by: CARiD
newbie/build advice. what am i missing?
Old Nov 28, 2012 | 04:48 PM
thenasty85's Avatar
so i have 85 toyota sfa i bought it to get into the wheelin scene and it did its job well but now i want more (its a curse) so i plan to put 6" springs with 2" blocks in back and 2" shackles in front then do a high steer conversion and weld the rear. and i came across a brand new set of 35" super swampers for trade to get a motor running so i plan on running those.
Is there anything that would be wise for me to do that im missing?
Old Nov 29, 2012 | 05:17 AM
Robert m's Avatar
gears
Old Nov 29, 2012 | 05:22 AM
dropzone's Avatar
Fossilized
why do you want it so high? 4" lift will clear 35's easily...5.29 gears
Old Nov 29, 2012 | 08:31 AM
thenasty85's Avatar
i wanted it that high because i dont want rubbage when i flex the springs
Old Nov 29, 2012 | 09:34 AM
EFI85's Avatar
not to be a sourpuss but its gonna drive like crap with that much lift . and you def wont be going nowhere with out gears
Old Nov 29, 2012 | 09:38 AM
93Xtra-Cab's Avatar
Blocks
6" springs and 2" blocks in the back?? You shouldn't need 8" of lift for 35s...
Old Nov 29, 2012 | 09:51 AM
moutainman4life's Avatar
just the six inch springs are plenty im running 37 inch bogers on five and never rub and the block will give you un wanted axle wrap and like every one else said gears and im a big fan of dual cases
Old Nov 29, 2012 | 10:00 AM
donomite49's Avatar
with lockers and you'll be good to go.
keep the center of gravity as low as possible.
rule of thumb, for every inch you go up go wider one inch to keep factory engineered stability.
Old Nov 29, 2012 | 10:14 AM
waskillywabbit's Avatar
Blocks suck
:wabbit2:
Old Nov 29, 2012 | 01:53 PM
thenasty85's Avatar
alright guys no blocks and different gears. this is why i started this thread thanks. dual cases are in store after next fire season is over.
Old Nov 29, 2012 | 04:06 PM
rokblok's Avatar
I would just do 3-4" springs with 6" shackles. That would give you ~4-5" of lift. Which is enough to clear 35s. Remember your goal should be big tires, low lift. Tires give you clearance, low lift keeps your center of gravity down for safer wheeling. All the 6-8" lift trucks are very limited in what they can do. Straight line mudding, they're great. Technical crawling or wheeling, they're useless... In my opinion...
Look at most, if not all, of the crawling competition trucks. 40"+ tires, very little lift...
Old Nov 30, 2012 | 01:40 PM
EFI85's Avatar
what he said /\
Old Nov 30, 2012 | 03:34 PM
ThatGuy1295's Avatar
Me 2
Not sure how much lift from stock mine is cause its a swap, but it aint no 8'', and im glad its not. Probably 5'' ish
Old Nov 30, 2012 | 10:31 PM
TrikeKid's Avatar
Move the front end forward a couple inches and you can run 35's at stock height with some trimming if you wanted to. The way these trucks are set up from the factory you could lift one 8'' with 35's and still rub the firewall if it actually articulated, they're just too far back for big tires in the factory location.
Old Dec 12, 2012 | 08:14 AM
BumbleYota's Avatar
I have a stock height 81 pu and have run 34s with no rub. I tried 35s but they would rub under strong articulation. I use slightly outset wheels. 35s actually ride well but like I said they will give you a touch from time to time.
Old Dec 12, 2012 | 06:52 PM
Good point. That bottom corner is always a trouble spot. Plus you get better approach angle by moving it forward.
Old Dec 12, 2012 | 07:32 PM
TrikeKid's Avatar
1st gen's have bigger wheel wells.
Corvoid
Oct 13, 2015 08:55 AM
Sam hain
19
Sep 30, 2015 08:25 AM
vikinghug
Sep 23, 2015 12:32 PM
Corvoid
Sep 14, 2015 10:10 AM
kportercpa
Engine Swaps
Sep 10, 2015 12:08 PM
