Sponsored by: CARiD
help with a suspension lift
Old Oct 1, 2012 | 09:11 PM
Thor17's Avatar
so I have a 1985 toyota 4wd pickup that I want to lift, and a rather limited budget to do it on. I'm considering doing a 63" chevy swap in the rear combined with shackles, hoping to get around 5 inches of lift. Is this realistic? Also, provided I do this, what is a good leaf spring option for lifting the front of the truck so everything is level (and preferably 5 inches further from the ground)? Thanks for any help you guys can give me.
Old Oct 2, 2012 | 12:17 AM
Thor17's Avatar
oh i forgot, what are pinion shims and what do they do? i know i need some for this lift
Old Oct 2, 2012 | 05:04 AM
waskillywabbit's Avatar
Search. Been asked a gazillion times.
:wabbit2:
Old Oct 4, 2012 | 08:43 AM
Thor17's Avatar
I know it's been done a lot, I was just hoping I could talk to someone who has done it before. I have heard people say the chevies will give you anywhere from 2 inches of lift to 6, im curious as to if anyone knows how much lift the springs give by themselves? I'm also planning on doing RUF for the front, but I wanted to see if anyone had other affordable options. At some point I hope to be running 35s
Old Oct 6, 2012 | 07:41 AM
thefishguy77's Avatar
I ran a 4" pos Rancho lift and had plenty of room for 35's on my 85 ex cab.
But seriously SEARCH find a build thread that mirrors what you want to do and then read it. If you still have questions you probably have found someone that has gone through it. Most of us are willing to help but just do your homework and search. if you can't find it on the yotatech search engine. use Google and put yotatech in as a key word. helps me find threads I have lost track of.
Good luck
Old Oct 6, 2012 | 02:49 PM
Thor17's Avatar
thanks thefishguy, I'm pretty confident I can do the chevy lift, I've read plenty of threads about it and whatnot, i just noticed that every single one i've read lists a different amount of lift. I'm assuming thats due to differing shackle length and drop hanger height. Also some people use rear blocks, but I want to avoid that.
Old Oct 6, 2012 | 03:59 PM
runs-on-4's Avatar
ruf are cheap for the springs. then you need to highsteer ,hoops, ifs box...
search first
Old Oct 6, 2012 | 04:05 PM
mudslinger457's Avatar
6 inch lift chevy springs should give your toyota a 11 inch lift
Old Oct 6, 2012 | 05:37 PM
rokblok's Avatar
I understand that properly set up Chev rears and shackles will gain ABOUT 3"-5" of lift. As I'm sure you found, there are different model for springs(2wd/4wd) and different folks seem to get different heights. Best to decide if you want 63s in the back and you may have to mix & match leafs to get your desired height.
Old Oct 10, 2012 | 05:55 PM
Thor17's Avatar
okay thanks. I'm definately planning on chevies in the rear, I don't see any reason why I should change that as yet.
nvdesertrunner
May 11, 2020 08:18 PM
Sep 4, 2015 09:27 AM
94ofCanada
Aug 14, 2015 06:37 AM
coffey50
Jul 28, 2015 10:55 AM
Vargntucson
Jul 4, 2015 12:15 PM
