Sponsored by: CARiD
cut out at high speeds
Old Nov 4, 2012 | 03:48 PM
spooner29's Avatar
my 86 22r pickup engine hase been shuttering at high speeds around 60mph then will do the same thing at low speeds 20 to 35mph ive change the plugs wires cap and rotor and also put a good used coil on it and it still does it i checked all vacum lines and cleaned out the vacum system with sea foam but nothing yet what could it be carb? carb float? fuel filter/fuel system please help i need to get to work 2marrow thanks guys i know you can help
Old Nov 4, 2012 | 03:49 PM
HighLux's Avatar
You pull the codes yet?
Old Nov 4, 2012 | 04:04 PM
spooner29's Avatar
i cant get any codes its to old to plug in and i tryed to do the check engine light trick but it seems i have no check engine light
Old Nov 4, 2012 | 04:14 PM
HighLux's Avatar
Hmmm. Well sounds like you have the spark side covered. Im leaning towards dirty carb. Check fuel filter?
Old Nov 4, 2012 | 04:23 PM
spooner29's Avatar
thats what im going to tackle next but i have no idea where the fuel filter is located is it an inline filter or in the carb and i think there is one in the tank also on the fuel pump but im trying to sty away from dropping the tank it cold working on my truck here in PA
Old Nov 4, 2012 | 04:29 PM
HighLux's Avatar
Here is a link to a Toyota Factory Service Manual for an 85. Should be pretty close. I dont have a carbed one...but this manual will have all you need.
Download file and unzip...I checked it...its a clean file and works.
http://www.truckporn.com/tech/FSM/Toyota/1985fsm.zip
Old Nov 4, 2012 | 04:35 PM
spooner29's Avatar
cool cool thanks this is guna help alot you will prbly hear back from me
Old Nov 4, 2012 | 05:30 PM
slow-mo's Avatar
The 22R models do not have any codes to trip. These are purely analog (mechanical) fueling systems.
Correct, for the same reason as stated above.
In stock form, there is no fuel filter in the tank. The OEM fuel filter is located next to the gas tank, inside the wheel well that the fuel filler neck is located.
Replacing the fuel filter is part of the regular maintenance, so that would be a good idea. Check to see what you fuel level is in the carburetor sight glass. The fuel level is supposed to be in the middle.
Old Nov 4, 2012 | 05:34 PM
HighLux's Avatar
Good to know that about the r models slo...thanks.
Old Nov 5, 2012 | 09:59 AM
slow-mo's Avatar
I have to quote myself for a little clarification.
There is a fuel screen in the tank for larger particles, but not a fuel filter.
Back on topic, one time I also have the engine stumble at freeway speeds. It ended up being the ignition wires. So the wires, distributor cap & rotor were all replaced. Also another regular maintenance procedure.
So check for the fuel filter to see if it is very dirty. Check to see where the fuel level in the carb. And if you have not done a tune-up recently, do that too.
Old Nov 5, 2012 | 02:11 PM
spooner29's Avatar
allright i got a filter today but unfornatlly i will not be able to put it on till 2marrow and i looked in my haynes manual and it has the filter location is just behind the carb on the firewall and i looked there is definatlly a filter there and i also looked at the sight glass i tryed putting a pick of it up but i can upload it and it is just below the center level there is like 2 tabs on the sight glass and the fuel is right at the top of the lower tab and thanks alot guys for the help agian
Old Nov 5, 2012 | 02:18 PM
rokblok's Avatar
My '84 22R fuel filter was accessible from the right rear wheel well. There is a small plastic cover that is held on by snap in retainers (Christmas trees) and a spring loaded clamp on each end of the filter. The filter itself is just held in by a large spring loaded wrap-around type retainer. Easily a 2minute job. Check there in addition to the one you found on your firewall.
Old Nov 5, 2012 | 02:26 PM
spooner29's Avatar
allright will do i will prbly end up replacing them both while im at it
Old Nov 8, 2012 | 03:38 PM
spooner29's Avatar
allright guys sry my net was down a few days and havent got to reply but i put the fuel filter in and i dident think this really matterd but when it started to run like crap i noticed my gauge lights were not working but i dident think it had anything to do with it running bad but i put the fuel filter in and my gauge lights came on and havent had a problam for the past 2 days i think maybe there is a short and it might be back feeding sumwhere and i also picked up a carb rebuild kit from napa and i am still going to rebuild my carb it needs it but agian guys thanks alot it helped so much
young buck
18
Aug 27, 2018 02:40 PM
kyletbert
Jul 17, 2015 11:39 AM
MTLroadierunner
Jul 15, 2015 12:58 PM
Nickdigg
Jul 7, 2015 06:04 AM
wilbertd
Jul 6, 2015 07:39 AM
