Sponsored by: CARiD
want start when warm
Old Nov 17, 2012 | 09:10 AM
bstewart983's Avatar
I have a 82 pickup with 22r and i can go outside right now and it will start right up. But if i go for a ride like to the store it want start back up until it cools a little bit. Any suggestions.
Thanks
Old Nov 17, 2012 | 09:34 AM
Bucholz24's Avatar
Head gasket? When you start it up does it leak water out the exhaust? or does the oil smell like antifreeze
Old Nov 17, 2012 | 01:00 PM
Oil looks and smells good and no water out of exhaust.
Old Nov 17, 2012 | 05:25 PM
Bucholz24's Avatar
sounds like maybe some sort of sensor?
Old Nov 17, 2012 | 05:53 PM
Mr.Utah's Avatar
Most likely a carb issue. When hot do not step on the gas when starting. Mixture could also be too rich, also try cleaning the carb with some seafoam.
Old Nov 17, 2012 | 06:59 PM
slow-mo's Avatar
For an '83, check your Hot Idle Compensator (HIC) on the carburetor.
Check to see if the carburetor is flooded after shutdown. It is common for the carburetors to leak fuel into the intake manifold and cause a no-start. If so, Toyota says to floor the gas pedal and hold it there until the engine starts.
Another way to see if the carb leaks is by checking the fuel level in the sight glass.
Doug4320
Mar 24, 2018 10:11 PM
Kluch8651
Jul 9, 2015 10:39 AM
raiderhawks00
Jul 8, 2015 06:23 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
karbin
Jul 5, 2015 11:37 PM
