want start when warm
I have a 82 pickup with 22r and i can go outside right now and it will start right up. But if i go for a ride like to the store it want start back up until it cools a little bit. Any suggestions.
Thanks |
Head gasket? When you start it up does it leak water out the exhaust? or does the oil smell like antifreeze
Oil looks and smells good and no water out of exhaust.
sounds like maybe some sort of sensor?
Most likely a carb issue. When hot do not step on the gas when starting. Mixture could also be too rich, also try cleaning the carb with some seafoam.
Originally Posted by bstewart983
(Post 52000956)
For an '83, check your Hot Idle Compensator (HIC) on the carburetor. Check to see if the carburetor is flooded after shutdown. It is common for the carburetors to leak fuel into the intake manifold and cause a no-start. If so, Toyota says to floor the gas pedal and hold it there until the engine starts. Another way to see if the carb leaks is by checking the fuel level in the sight glass. |
