Sponsored by: CARiD
1990 4runner suspension
Old Oct 29, 2012 | 10:57 AM
thezrutherford's Avatar
ok so i am planning on lifting my '90 4runner, i already have 1.5 bj spacers for the front and 1.5 coil spring spacers. I was looking into getting the ome 2inch coilsprings and putting my spacers on those, then doing a t bar crank so it will be level. will there be any issues with this set up and what else would i need (longer shocks, longer brake lines, etc.) thanks
Old Oct 29, 2012 | 06:18 PM
RobD's Avatar
One, it will ride like crap with the torsion bars cranked that high. Two, you're going to be putting serious strain on your CVs.
Old Oct 29, 2012 | 06:24 PM
What if I upgraded to ome torsion bars
Old Oct 29, 2012 | 06:53 PM
4x4 Runner's Avatar
You'll want new shocks if you plan on offroading. Rather than cranking your torsion bars, get new coils up front. Unless you don't care how it drives and just want it lifted.
Check out toyteclifts.com
Good luck man. Let me know if you have any more questions!
Old Oct 29, 2012 | 06:55 PM
4x4 Runner's Avatar
Also, you'll definitely want a front differential drop kit. They are only around $15, easy to install, and will save your CV axels.
Old Oct 30, 2012 | 04:40 AM
They have front coils for 2nd gens? And what kind of shocks do I need for this set up
Old Oct 30, 2012 | 08:25 AM
4x4 Runner's Avatar
Toytec actually doesn't have too many options for 2nd gen 4runners. Try 4crawler.com
Toyteclifts front shocks: http://www.toyteclifts.com/index.php...mart&Itemid=72
Rear shocks: http://www.toyteclifts.com/index.php...mart&Itemid=72
Those are the cheap shocks.
If you want a complete OME lift package: http://www.toyteclifts.com/index.php...mart&Itemid=72
Old Oct 30, 2012 | 12:38 PM
sweet thanks man, and what else can i do to lift the front, im not looking to pay over 500 for a complete kit and if i do crank the t bars anything else i should do to the front end?
Old Oct 30, 2012 | 12:53 PM
4x4 Runner's Avatar
I'd say get Toytec's:
2" rear lift OME coils (and add the spacers you already have into those new coils)
The rear shocks I sent you the link to
For the front you can add another spacer or crank the torsion bars.
And then get the front shocks I sent you the link to.
It won't ride the best but will look great!
I have 3" lift rear coils, front spacer, new shocks all the way around on my 3rd gen and I love it. The OME coils aren't as smooth as stock but still great coils.
Let me know if you have any more Qs man.
Old Oct 30, 2012 | 12:57 PM
thanks man youve made this a lot easier, i think thats what im going to do, do i need a panhard relocation bracket? and the sway bar drop kit?
Old Oct 30, 2012 | 01:17 PM
4x4 Runner's Avatar
To be honest I'm not sure for the 2nd gens. I didn't need either of those for my 3rd gen. On Toytec's website you can email them and ask them questions. Email them and tell them what set up you're going to be using and ask if you'll need a new panhard bar or a relocation bracket for it and/or sway bar.
Like I said I didn't need either of those on my 3rd gen 4runner. I did a OME 3" on a 2nd gen and didn't do either of those either. So you should be good but email Toytec and ask them just in case!
Old Oct 30, 2012 | 01:18 PM
4x4 Runner's Avatar
Also when you email Toytec, ask them about a front differential drop kit for the second gens. I didn't see one on their website
Old Oct 30, 2012 | 01:24 PM
BeMiceElf's Avatar
There are no other spacers you can add to the front. You could get a drop bracket kit.
And no, and won't work great. You will have little to no down travel.
Old Oct 31, 2012 | 11:02 AM
what wont work great?
Old Oct 31, 2012 | 12:51 PM
JonnyBoy's Avatar
I had a hard time keeping the front level with the rear with just the OME 900 springs in the rear, you'll never pull it off with the coils and the spacers in the rear unless you get a bracket lift setup for the front. If you went with thicker torsion bars and cranked the crap out of them to get as close as possible, your suspension would be pretty much all the way topped out. Even if you got a diff drop, it would still be hard on your cv's and steering parts.
If you want 3 1/2 to 4 inches of lift, you need to save up and do it right for the front, but the OME springs and spacer are ok for the rear. Yes, I would recommend a panhard drop bracket, and if you like your swaybars get extensions for them, too. With spacers on top of the lift springs, I think I'd also recommend rear shocks for a Land Cruiser fj80 instead of the Runner shocks, mostly to prevent topping out the shocks with that much height.
Old Oct 31, 2012 | 08:03 PM
What if I just got the 2inch lift coils from toytec and didnt put the spacers on the
Old Oct 31, 2012 | 09:26 PM
JonnyBoy's Avatar
How big are you planning to go in the end? What do you want the rig to be good for in the end? If about the height of the 2" coils plus your spacer, then I would get the springs, leave that spacer off, and then just decide if you need it soft in front or not.
If yes, install ball joint spacers and level it to the springs in the rear. If not, just turn the torsion bolts til you have the desired ride height.
After either front end plan, get an alignment, then start saving for bigger and better for the front.
Are you lifting it for looks? Clearance for tires? Crawling? High speed over rough roads?
Old Nov 1, 2012 | 04:39 AM
I just ruined my clutch due to hard mudding s for the time being just looks but I drive a lot and eventually want to clear 33s
Old Nov 1, 2012 | 02:37 PM
JonnyBoy's Avatar
Ok, well if the majority of the wheeling you do is in mud you wouldn't really need to put the ball joint spacers on. I still would if I were you. With a little careful trimming, you could then fit 33x12.5's with no or very little rubbing. You could fit 33x10.5's with the same trimming and not even lifting it, though.
Old Nov 1, 2012 | 04:10 PM
I'm probably going to leave it on pavement for a while so I'm looking for te best ride a d looms
Jun 1, 2021 01:51 PM
MMA_Alex
25
Apr 18, 2017 05:07 AM
madxman21
Jul 9, 2015 10:26 AM
ptb12
Jul 5, 2015 01:49 PM
Vargntucson
Jul 4, 2015 12:15 PM
