Sponsored by: CARiD
Preparations needed to drive 4runner 400 miles.
Old Oct 14, 2012 | 06:09 PM
Bullet22r's Avatar
Hi guys i am new to this forum and i was just wondering on what should be done to get a 1985 4runner to travel 400 miles. Okay so my uncle is giving his truck to us and he lives up in the bay area and I live in L.A. it has not been ran for 5 or more years and tips on making it home will be highly appreciated thanks in advance.
Old Oct 14, 2012 | 06:19 PM
brianh699's Avatar
Check fluids oil, power steering, brake, clutch and coolant. If it runs good and drives good, just go it's a Toyota!
Old Oct 14, 2012 | 06:27 PM
ksti's Avatar
If it hasn't been run for at least 5 years, I'd be changing all the FLUIDS. If you have the time and it's running I would take an extra day or two and drive it around the area. Just my 2 cents worth, Good luck with the trip.
Old Oct 14, 2012 | 11:49 PM
wyoming9's Avatar
Red face
Fresh gas for sure!!
It would not hurt to change the oil as well as top off the coolant.
Why was it parked for that long??
I sometimes think the more you know about this stuff the more paranoid you get about things failing in route.
Old Oct 15, 2012 | 06:50 AM
Robert m's Avatar
check the tires for cracks and leaks and make sure you have a good spare
Old Oct 15, 2012 | 07:08 AM
dropzone's Avatar
Fossilized
Tow it..
Five years..getting a trip permit or just taking your chances on no tags?
Old Oct 15, 2012 | 07:39 AM
MaK92-4RnR's Avatar
I drive to pismo from sacramento once a year. the only thing i do before i leave is change the oil, replace the air filter, and top off coolant. lol pack up and go!
Old Oct 15, 2012 | 09:00 AM
derockus's Avatar
Originally Posted by dropzone
Tow it..
X2, tow it. If you're asking then you must suspect there's something wrong.
What's worse, no/expired tags or swapping on some current tags from a different vehicle? I think you'd be less likely to be pulled over with current tags but IF you get pulled over it might be a bigger penalty? Honestly, I don't know.
Check all the signal and brake lights if you're driving, another thing not to get pulled over for.
All fluids including gas. Take the air filter out and make sure no critters have gotten in there. I'd drive it around the block and make sure it gets up to temp without any hoses bursting, could be old and dry rotted. Same goes for the belts. In fact, better bring some hoses and belts with you in case they blow on the highway. Have you thought of avoiding the interstate altogether?
Old Oct 15, 2012 | 12:39 PM
Bullet22r's Avatar
thanks guys for the tips and i was also thinking about towing it but i dont have a vehicle to tow it with, and im prolly just going to get a permit for it. about the fluids would you also change differential and transmission fluid? it has a manual transmission
Old Oct 15, 2012 | 12:43 PM
Bullet22r's Avatar
he got another vehicle for his daily driver.
we used to take it to Pismo and go to the dunes with it, it was fun.
JF9243176
Oct 8, 2017 04:21 AM
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
Alex Bessinger
Jun 28, 2015 10:05 AM
HALMAN
Jun 14, 2002 09:02 PM
