Sponsored by: CARiD
Driveshaft Direction?
Old Nov 26, 2012 | 05:13 PM
Mr. Spooky's Avatar
I took my rear driveshaft off and I totally forgot which direction it goes. Or does it matter? Does the slip go near the diff or the tcase?
Truck is a 1980 4x4 if it matters.
Old Nov 26, 2012 | 05:20 PM
rworegon's Avatar
OP added year so removed info for later years.
Old Nov 26, 2012 | 05:36 PM
westjohns yota's Avatar
slip goes towards the t-case, thats how it beens on all my earlier model pickups
Old Nov 26, 2012 | 06:02 PM
mudpunisher's Avatar
ive seen them both ways, but i'm pretty sure the correct way is slip to the t-case. a buddy of mine has his the other way and claims its so gravity will help water and other stuff not stay trapped. i dont really think it matters as long as the shaft is in phase.
Old Nov 26, 2012 | 06:42 PM
dropzone's Avatar
Fossilized
I ran my old shaft both directions.
now that I had a new CV equipped shaft, slip is at the axle
Old Nov 26, 2012 | 07:06 PM
Mr. Spooky's Avatar
thanks for the help! I can see running it slip at the diff for the mentioned water reasons but I would think that running it at the tcase would keep the splines off the rocks.
Old Nov 27, 2012 | 12:13 AM
wyoming9's Avatar
Red face
Most likely you forgot to put on any match marks to get it back on the same way.
Might be good to search getting your drive shaft in phase.
Old Nov 27, 2012 | 04:45 PM
Mr. Spooky's Avatar
you are right, but I didn't replace the U joints, just removed the driveshaft. That is the next project, and I will be sure to mark this time. Unless the trend continues that the previous owner didn't do a thing right on this truck. So yeah I better research how to do that correctly.
Old Nov 27, 2012 | 05:15 PM
junkyardog05's Avatar
slip joint goes to the transfer case it helps to take some of the load off of your rear output shaft.
kawazx636
Oct 6, 2021 03:03 PM
TheBFA
Feb 15, 2020 06:55 AM
live4soccer7
May 11, 2016 06:52 PM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
hiluxinargentina
Sep 30, 2015 05:51 PM
