Sponsored by: CARiD
94 truggy suspension
Old Oct 6, 2012 | 09:13 PM
progressing94truggy's Avatar
im getting ready to start a project truck. i have a 94 toyota extra cab that was rolled and i want to turn it in to a crawler i have a front straight axle with factory 5 inch lift springs and a rear axle that im considering converting to coil suspension instead of leaf springs. there will be no bed just tube cage and i want my shock mounts to be higher than the frame. basicily i just need to know where to start. where should i mount my shocks and coils. what shocks do i need what coils should i use?
Old Oct 6, 2012 | 11:30 PM
dropzone's Avatar
Fossilized
5" factory lift? Where did you find those?
Old Oct 7, 2012 | 05:25 AM
waskillywabbit's Avatar
If you are asking where to start on such a project, you need to find an easier project.
:wabbit2:
Old Oct 7, 2012 | 06:30 AM
I just mean the lift springs sold on trailgear.com sorry if I worded that wrong. As you can probably tell im new to this whole thing.
Old Oct 7, 2012 | 06:35 AM
Leaf springs are much easier to set up and cheaper than coil springs. I'd start with leaf springs.
:wabbit2:
Old Oct 7, 2012 | 06:33 PM
Ok thanks. so I picked up a pair of 63 inch chevy springs for 50 bucks. I figured deal like that I cant pass up. So im thinking about shortening the distance between the front and rear axles. Keep in mind i have the extra cab so ihave some room to play with. How far back should I mount these 63 chevys? And im assuming ill need some pretty long rear shackles and maybe a couple inch lift blocks to level it out?
Old Oct 7, 2012 | 06:46 PM
rattlewagon's Avatar
Read this for the 63s"
http://www.pirate4x4.com/forum/toyot...-swap-faq.html
Many companies such as Low Range Offroad and Sky Mfg make kits to hang them.
Also read this:
http://forum.ih8mud.com/79-95-toyota...er-thread.html
Old Oct 8, 2012 | 10:21 AM
Thank you those links helped alot. Ok so I keep hear about it so I have to ask. Where to I go to find add a leafs for my 63 chevys? Do I just pick them up a junk yard or is that kit sold on certain web sites? Also what about a sas? Ive done alot of research but I cant find any shortcuts or money savers. Everything just says to buy the expensive do it your self kits. Any tips/ideas?
Old Oct 8, 2012 | 10:30 AM
James Woods's Avatar
Money savers? Build your own hanger and shackles, that will save some money, wont be a short cut though. Either way you cut it, your going to spend some cash on a SAS, if it were easy and cheap everyone would have done it by now.
You can find add a leafs at most likely any off road supplier for Chevy springs.
Old Oct 8, 2012 | 08:29 PM
thanks for all the help you guys. so a buddy of mine owed me some money so we settled on trading for a toyota straight axle he has. i havnt seen it yet but he says its already trussed, it has a locker, not sure what kind but im guessing its just a clicker, boby longfields? not sure a whole lot about those just know they are stronger, something about 30 spline axle shafts..which i think might be the bobby longfields, and some kind of heavy duty bearings. any comments on that?
Old Oct 8, 2012 | 10:36 PM
VANCE164's Avatar
Sounds like a built axle I'd take it!
Old Oct 8, 2012 | 11:49 PM
drew303's Avatar
mmm I like Truggys.... and whiskey...and wild wild women.
Did I help?
Old Oct 9, 2012 | 09:33 AM
I think ill keep it then. so im thinking about running 37 inch tires possibly bigger and im interested in dual cases but should I consider 5.29.'s in ny axles before the duals? And if anyone knows a good link for gearing/ and or dual cases I would appreciate it
Old Oct 9, 2012 | 06:42 PM
drew303's Avatar
Www.gearinstalls.com
You will need 5.29 yes
If you're gonna roll 37 you'll need to upgrade the front inner axles to atleast chromoly. 30 splines if you're gonna do dual cases
Old Oct 9, 2012 | 06:43 PM
drew303's Avatar
I'm going down to a 35. I drive my junk on the road to much and anything over 35 is nearly TWICE the cost per tire. Fyi
Old Oct 9, 2012 | 09:48 PM
Thank you that helps alot I did not know that. And I do have the 30 spline chromoly axle shafts in the front with a locker in it. Is the locker and the big tires and low gears going to be able to break that axle shaft? What about the rear, will it break if I have stock axle shafts and lower gears? I figured id thrower clicker locker in it. Will it definetly break then? And still if anyone has good links for any of this stiff that would help alot. Esspessially on the dual cases. Thanks
Old Oct 10, 2012 | 01:57 PM
drew303's Avatar
You can break anything lol
I've had buddies kill dirty thirties with dual cases. Long fields too... Its a matter of luck and how hard you bash your stuff.
There's a thread on here somewhere a guys rear axle shaft sheered on the road. I'd upgrade the rears. $150 a chromoly shaft. Requires some special tools to swap brakes bearings etc tho fyi
Old Oct 10, 2012 | 02:05 PM
drew303's Avatar
Keep in mind there are lots of variables are work when breaks happen and why they happen. Just because someone broke inners on 37s doesn't mean you would in the same situation.
For example you're a helluva lot more likely to grenade parts running 37x13.50 17 toyo MTs vs a Goodyear 37x13.50 15 MTR. There's a HUGE difference in wheel+tire weight. Massive. One of my MTRs weighs roughly 75#. A 35x1250 bfg km2 is 52# and not that toyos are nearly 90#s before a 17" wheel.
Food for thought
Old Oct 10, 2012 | 02:06 PM
drew303's Avatar
Excuse the bad grammar I'm on my phone and auto correct is owning.
Old Oct 10, 2012 | 10:07 PM
Thanks for the tips. So other than upgrading to full sized axles...is there anything that can be done to beef them up past the 30 spline bobby longfields. And just a side note, just had my 33-12.50-15 toyo mt's with toyota rims stolen last night.
