Sponsored by: CARiD
3.0 problems
Old Nov 28, 2012 | 05:08 PM
1stgenman!'s Avatar
3.0 problems
so im new to this site but not totally new to yotas. im from shelbyville ky and would love to find some toyota people around my area.
But anyway i recently just purchased an 88 4runner 3.0 v6 5 speed. theres 250k on body which is in great shape and 91k on motor tranny swap from a 91. (or so the p/o said) now the truck runs amazing but at idle when at low rpm it likes to run rough. its not overly bad but you can def tell its there. the wires are good and spark plugs are fine. nothing is leaking out of it so idk.
i have heard that the 3.0 do run like that sometimes for some odd reason but i thought i would ask some of you guys first. thanks
any feedback would be greatly helpful.
thanks
-wyatt
Old Nov 28, 2012 | 06:01 PM
coastal runner's Avatar
does it occur when she's cold or hot? or just whenever she's idling?
Old Nov 28, 2012 | 06:04 PM
1stgenman!'s Avatar
it will do it during both. i adjusted the idle and it helped a little but its still there
Old Nov 28, 2012 | 06:11 PM
ksti's Avatar
Dirty throttle body, dirty air cleaner, possible vacuum leak. Dried up corroded o-ring on idle air screw. That's just a few things it could be. Any recent service records? What brand are the plus and wires?. Did you pull and check them.
Old Nov 28, 2012 | 06:13 PM
1stgenman!'s Avatar
well i took it to a mechanic buddy of mine cuse im hard at it at work lately and dont have much time and he said he couldnt find anything. he checked the plugs and wires, it wasnt running to lean or rich. im sure he went over the things you just asked but ill ask him tomorrow. this coming week i should have some time so i might be able to tear into some more. keep the help coming tho. i need it
Old Nov 28, 2012 | 06:19 PM
ksti's Avatar
What was it idling before you adjusted it and where is it now operating temp?
Old Nov 28, 2012 | 06:21 PM
^^ yea that, how many rpms
Old Nov 28, 2012 | 06:27 PM
1stgenman!'s Avatar
mm it was probably at 600rpm now closer to a 1000. operating temp is still normal tho
Old Nov 28, 2012 | 06:38 PM
ksti's Avatar
Idle speed 800 +- 50 at operating temp.
Old Nov 28, 2012 | 06:41 PM
1stgenman!'s Avatar
ok im pretty sure its close to that. i ll have to check tomorrow. thanks so far tho
Old Nov 28, 2012 | 06:48 PM
ksti's Avatar
My advice would be, get a factory service manual, you might be able to download one, but might be difficult as source for this has been discontinued. There is alot of info on rough idle for 3vzzzy's. Good luck with your rig and post up on the idle gremlin.
Old Nov 29, 2012 | 07:47 PM
1stgenman!'s Avatar
so i i think i may have found out what my idle problem was. i have a small pin size hole in the incoming fuel line above the drive shaft!
should i do a patch kit. take out the hole with excess of an inch on each side flare the ends of the existing tube and slide and clamp over a gas rated rubber one?
should i just get a whole new line so i dont have to worry about another leak?
Old Nov 30, 2012 | 02:47 PM
1stgenman!'s Avatar
so i wasnt totally wrong about it being the fule line. i fixed that problem and its doing better but after it sits for a bit and i go to start it up and will start but has some trouble getting to a smooth idle. once i start to drive a minthen back to an idle it rusn fine..
thoughts?
Charecter1
Nov 6, 2023 10:08 AM
tobylab
Jan 18, 2016 07:06 PM
Alex Bessinger
Aug 31, 2015 09:17 AM
tobylab
Jul 12, 2015 12:53 PM
Coreyr384
Jul 10, 2015 11:13 AM
