Sponsored by: CARiD
adding power
Old Nov 3, 2012 | 01:56 PM
85celicagthatchback's Avatar
adding power
hey guys me and my dad have been building 22rs for the last 4 yrs out of are shop. and weve been trying to come up with ways to add decent power to a 22r with out having to charge alot of $$$$$$. so with that said i would like to see what u guys think if u would buy this packages if we started to produce them so here it goes.
stock head replacement with new cam and springs and valves $320 now heres what u could add to that for different amounts of $$
up graded cams range from .380 lift at $100 to a .460 lift at $200 plus $50 cam core. up graded rv valve spring these give so much better throttle responce $70 upgraded pocket blending 100 bucks this raises the head flow from 115cfm top 135cfm @.450 lift or upgraded fully ported $250 that increase the heads flow to 170cfm @.450 lift now when i say fully ported i mean as ported as ud want to go on a street car or a rock crawler.
now thats the head i used to get my 145whp on my 85 celica with are .440 cam and springs so that can give u a guess at the whp ud get with those up grades. so that $840 for 53whp upgrade using my celica's stock whp rating.thats $15.83 a horse power
So is that worth is too u guys?
Old Nov 3, 2012 | 02:01 PM
also are stock rebuild engines with just the .400 cam made 89.78 whp and 113.03ftlbs that's 107hp to the fly and 135ftlbs at the fly. it was turning 35" wranglers with 4.88 gears all stock air and ex.
Old Nov 3, 2012 | 02:19 PM
wyoming9's Avatar
Red face
i wish you well.
But your going to need a track record before you can make any money. Why would I buy from you and not from Ted and Todd??
Then again when it becomes for profit it is amazing how soon it is no longer fun
I think the whole idea of spending that much on just the top end is a bit much because to install the head your also doing the bottom end at the same time or you will be shortly.
Do good head work you will be more then busy enough.
I can get a bone stock 3.4 and come away with quite a bit more Horsepower.
I wonder if anyone put a 3.4 in a 3rd generation Celica. It is not like i need more to do.
Old Nov 3, 2012 | 02:53 PM
just trying to see if people would be into getting kits like this to sseee if its worth making them or just stick to whole engines thanks for ur input and u should buy from us cause we offer cheap godd reliable power.
Old Nov 3, 2012 | 02:54 PM
if guys are more into changing out a whole eninge and thats what i find by posting this then will just offer more high performance longblocks
Old Nov 3, 2012 | 03:00 PM
ive considerd the 5vz swap but didnt know about trans options but would make the car move
Old Nov 3, 2012 | 05:29 PM
donomite49's Avatar
yea 5vz 3.4 stock 190 HP220 fp of torque.
with supercharger add 55, with underdrive pulley and water/meth injection you're at 300.
i saw a dyno run posted on yotatech, a 3.4 SC was pullin 380 at the crank 300WHP.
if you search you should find it, i'll try to find and post.
Old Nov 3, 2012 | 06:55 PM
ksti's Avatar
You got a dyno or some kind of spec sheet on all these #s your quoting?.
Old Nov 4, 2012 | 07:14 AM
donomite49's Avatar
heres a 3.4 with #s we can all wish for,
http://www.customtacos.com/gallery2/...Mods_List3.JPG
Old Nov 4, 2012 | 02:48 PM
Ksti yes I've dynoed the truck like I stated I have.entire sheet to prove don't know.how to up load though. can u guys tell me if these prices to HP.gain interest u? I'm not looking to start a post of how u should just do a swap or not
Old Nov 4, 2012 | 02:52 PM
Ok so his truck with all that stuff is as fast as my celica with just a head and ex on it.
Old Nov 4, 2012 | 03:02 PM
donomite49's Avatar
that truck makes almost three times the HP of your car...
good luck trying to sell your head and ex...
if you want to be rock star status you should learn how to play music not sell some "magic elixar".
Old Nov 4, 2012 | 03:42 PM
Yes ur right he makes more power but he weights more too. HP isn't everything. But thanks for ur in put
Old Nov 4, 2012 | 03:52 PM
HighLux's Avatar
Please go away. (Sweeps you off the forum with a 22re powered broom)
Old Nov 4, 2012 | 05:06 PM
ksti's Avatar
^HeHe
delmert
Sep 30, 2015 04:34 PM
Griff
93-98 T100s (Build-Up Section)
Sep 23, 2015 10:11 PM
justdifferentials
Just Differentials
Aug 15, 2015 05:25 PM
Sidherish
Aug 2, 2015 01:42 PM
Logz808
Jul 26, 2015 07:09 AM
