Sponsored by: CARiD
4Runner hesitating at 2K RPM - help
Old Jan 17, 2008 | 06:06 PM
hittman's Avatar
Question 4Runner hesitating at 2K RPM - help
Any help diagnosing this problem would be GREATLY appreciated. Just got a 4runner SR5 4X4. My problem is that the engine hesitates around 2K RPM, especially noticeable in 2nd and 3rd gear but it runs fine at highway speeds. I'm at 200K miles and It has new plugs, I just replaced the plug wires, dist cap and rotor. It idles fine, only rough when in gear. Any ideas?
Old Jan 17, 2008 | 06:17 PM
Chrisnxl185's Avatar
what engine, year??
Old Jan 18, 2008 | 04:41 AM
hittman's Avatar
sorry, 1995
Old Jan 18, 2008 | 05:13 AM
have you ever tried seafoaming it? Seafoam is an engine cleaner. a lot of people say great things about it. i tried it myself, notice a little less hesitation with my truck. Search Seafoam on this forum you'll find out more
Old Jan 18, 2008 | 05:26 AM
Trail_Banger's Avatar
My guess is that it's electrical, possibly a throttle position sensor (TPS), but what the hell do I know? :-)
Just to add what hittman says (because I've actually driven the truck) is that when you're in neutral the engine runs fine at all RPMs. We only experince the hesitation when in gear (between 1500 and 2500 RPM).
Anyone out there think it may be a TPS? Does anyone out there think plugging in an ODB2 reader in would give us a trouble code? There's no check engine light on right now.
Anyway....hittman needs to tow a trailer 3200 miles next week so if someone has a suggestion, let er rip.
Old Jan 18, 2008 | 05:52 AM
toy_tek's Avatar
What engine is it?
Old Jan 18, 2008 | 07:03 AM
CyMoN's Avatar
I would check your grounds and the intake hose in between the Maf and TB if the hose has a small leak it can make the truck stumble.
Old Jan 20, 2008 | 07:17 PM
hittman's Avatar
TPS passes the resistance test using an ohmmeter and is fine. No apparent leaks in the intake hose either. Noticed that it is using up oil (not leaking on the ground) and idles a bit rough too. I'm beginning to think the worst, but hoping it's not a compression issue. I'm going to take her in to see the doctor tomorrow...hope it's good news.
Old Jan 23, 2008 | 10:09 AM
I'll post ths fix for hittman, because he's a slacker.
The problem was a cracked plug. Now she runs fine.
JB
Old Jan 24, 2008 | 06:07 PM
hittman's Avatar
sorry for being a slacker, but a functioning toyota can cause anyone to spend less time at their computer
Old Jan 24, 2008 | 06:37 PM
Brenjen's Avatar
Could be a lot of things, is it timed correctly?
Nevermind I see you got it.
Old Jan 25, 2008 | 05:59 AM
Ha ha ha!! Just busting your b*alls. :-)
Flightguy
Oct 2, 2015 05:34 PM
Jdgarrison
Oct 1, 2015 05:22 PM
Jdgarrison
Oct 1, 2015 02:11 PM
shredder4286
Oct 1, 2015 01:09 PM
anniesball
10
Sep 15, 2015 05:41 PM
