Sponsored by: CARiD
another 2nd gen rear window!
Old Jan 7, 2008 | 07:38 AM
sleaz22xx's Avatar
iproblems with my 2nd gen rear window, ive tryed 3 different window relays to no evail, ive properly seated the rear wiper, ive made sure there is no mechanical binding, ive done enough all the research, still stuck!!
the window is stuck close, but is down about a half inch, when i get in to cab and use the window switch i here the window go CLANK but no movment,
and then i try down, CLANK no movment, i have a replacement motor that i would like to try but cant seem to figure out how to remove the old one with the window up, please any help is greatly appreciated
Old Jan 20, 2008 | 06:46 PM
colsoncj's Avatar
ok, may seem like some dumb simple questions, but bear with me:
1. have you check for any obstructions that would prevent it from coming down?
2. I assume the mechanism is similar to a 1st gen (what I have exp with, so thats what im basing the rest of the question on), and if it is, it should have two swing arms that have rollers at the tips that ride in the track attached to the bottom of the window. Have you checked these rollers and track for any abnormalities?
Old Jan 20, 2008 | 06:54 PM
DeathCougar's Avatar
Sounds like the window gear is stripped or the motor housing is worn out, OR the regulator is stripped. All three very common problems for 3rd gen 4Runners, especially in areas where they salt the roads (IE Boston)
Old Jan 21, 2008 | 04:11 AM
GSGALLANT's Avatar
crawl into the back of your truck, pop the carpet panel off the tailgate, remove the screws that hold the metal panel on, and have a looksee in there to see if anything looks out of place. It's a little more awkward to do it with the tailgate closed, but you can even remove the regulator and motor from that position if you need to. That will allow you to lower the window and open the tailgate so that you're a bit more comfortable working in there.
Old Jan 21, 2008 | 01:42 PM
WCorbett's Avatar
is the window lock button pressed?
Old Jan 21, 2008 | 01:52 PM
94Runner4x4's Avatar
beat me to it!
Old Jan 21, 2008 | 01:54 PM
sleaz22xx's Avatar
The motor was beat replaced it and everything is great now, Had a tuff time getting the motor removed with the tailgate up, Its a little tight but i reached behind the motor to get two of the bolts out, the third bolt can be easily accessed by removing the liscence plate holder and lights on the outside of the truck and reaching a extension socket threw the back of the truck, clean everything out and lube it up, golden! FYI window motor from left side of most model toyota's of similiar years will work. Thanks for the help guys!
Old Jan 21, 2008 | 01:59 PM
sleaz22xx's Avatar
I tend to check all reasonably easy causes first( IE window lock) BEFORE a post and waste others time on an other wise informative site.
Thanks
Old Jan 22, 2008 | 04:04 AM
GSGALLANT's Avatar
If the window was locked out with the window lock button, it wouldn't go CLANK when he tries to raise or lower the window. It just wouldn't do anything at all.
Old Jan 22, 2008 | 05:28 AM
colsoncj's Avatar
Good work, glad you got it fixed! Also, nice tip on the motor compatibility.
Old Feb 12, 2008 | 10:50 AM
Matt16's Avatar
The wrecker I spoke with was of the opinion that that window motor from a Toyota of similar vintage was geared differently, its this true?
Old Feb 12, 2008 | 08:56 PM
stormin94's Avatar
Mine works reguardless...
Old Mar 25, 2008 | 08:00 AM
Aywilkerson's Avatar
wher can you get the window tracks if they are all rusted out. wanted to look in a salvage yard but figure they would be about the same
Jun 1, 2021 01:51 PM
icentropy
Jul 14, 2015 10:23 AM
Steezy96yota
Jul 6, 2015 10:00 AM
coryc85
Jul 6, 2015 04:07 AM
HRDC0R19
Jul 5, 2015 06:43 PM
