Sponsored by: CARiD
little help w/33x10.5 on stock
Old Dec 22, 2007 | 11:01 AM
tank1's Avatar
i have 94 ext 4x4 22re 5sp i think it has 4:10 gears completely stock. I hear you can run 33x10.5 on this with no lift and on stock rims,the rims i have are 15x6 will it still work and what else is needed to do this
thanks
Old Dec 22, 2007 | 11:04 AM
tank1's Avatar
little help christmas is almost here!!!!!!
Paul H.'s Avatar
I do not believe that you can run 33X10.50 with no lift 32's is max with no rubbing I have been told. And I would not run 10.50's on a 6 inch rim. 7inch would be much better.
Old Dec 22, 2007 | 11:09 AM
tank1's Avatar
yeah thats what i was thinking, these 15x6 rims might have to go to open up so more options..
Old Dec 22, 2007 | 11:10 AM
tank1's Avatar
wish truck would have come with the 31 tire option,that way i would hve gotten the nice aluminum rims..........
Old Dec 22, 2007 | 11:15 AM
881stGenRunner's Avatar
you have a 3rd gen truck which is the same as a 2nd gen 4Runner. you CAN fit 33x10.50s on her stock. TC has done it. and someone was even able to fit 35x10.50s stock. get a cheap pair of STOCK aluminum wheels off craigslist or here and you'll be good.
Old Dec 22, 2007 | 11:24 AM
tank1's Avatar
have some old outlaw i's off an old chevy but the studs on the toy arent long enough to make it throught the rim. dont know if you can change those out,or might be better off buying new rims
Old Dec 22, 2007 | 11:57 AM
BLKNBLU's Avatar
Check your local Craigslist. People out here are constantly selling them as takeoffs at reasonable prices. Shipping kills if you get them online anywhere (ebay) All the Toyota 6 lug patterns are the same, so whaterver style you find will fit, but try to get some with the lugnuts because toyota lugs are unique.
Old Dec 22, 2007 | 12:00 PM
tank1's Avatar
thought i wanted some off the 96-2003 but not real sure i think those are 15x7 or 15x8....which would work great but everybody wants big $$$$$ for them...
Old Dec 22, 2007 | 12:11 PM
bigarms23's Avatar
they shoud fit cause you actually have 15x7 stock toyota rims
Old Dec 22, 2007 | 12:15 PM
tank1's Avatar
i have the stock steel rims that are 15x6 so i need to get something different i so i can change these tires,not too big just big enough
Old Dec 22, 2007 | 12:18 PM
BLKNBLU's Avatar
Thats odd. I see them regularly here in AZ for $100-$200. Sometimes the newer 17" ones are higher.
Old Dec 22, 2007 | 12:19 PM
jfreisner's Avatar
search.
Old Dec 22, 2007 | 12:26 PM
tank1's Avatar
yea ill start looking a little harder,around here in south georgia there a little harder to come by guess ill venture out to find them..Will any year 4x4 tacoma or pickup fit the 94????????that where im getting confused
Old Dec 22, 2007 | 12:27 PM
tank1's Avatar
What year rims have yall seen that will look good on this 94 truck
Old Dec 22, 2007 | 12:33 PM
BLKNBLU's Avatar
From a bolt pattern standpoint they will all fit. 15's, 16's, and 17's. It's just a matter of getting what YOU want. Yeah sometimes those craigslist ads are a bit lacking on info.(I don't know what size they are but they're stock) Duh. The 15's and 16's are both 7 inches wide. I think the 17's are 7.5 So just clarify with the seller that they ar 15's.
Old Dec 22, 2007 | 12:36 PM
tank1's Avatar
any years you think would look better than other on these trucks,,this is my
1st yota so little lost in all these forums....
Old Dec 22, 2007 | 12:45 PM
tank1's Avatar
hey BLKNBLU i see in your sig that you have a lockright in the rear...hows that working out for you, i pretty sure ill be getting locked somehow in the near future....any up or downs to these .....
Old Dec 22, 2007 | 12:47 PM
BLKNBLU's Avatar
Oddly enough, they all look pretty good on any generation. Here are a couple examples on first gens.
https://www.yotatech.com/forums/f123...im-club-93859/
https://www.yotatech.com/forums/f100...arizona-99471/
Old Dec 22, 2007 | 12:50 PM
tank1's Avatar
yep thats the ones i want...........are those 96-2000 year models????
