Sponsored by: CARiD
Coolant Level 1982 22r
Old Nov 6, 2007 | 04:45 PM
rowdy235's Avatar
I was wondering where the coolant level should be on my 1982. I checked it the other day and the coolant was around 1" down below the filler neck on the radiator, the tank was right between the "HI" and "LO" marks. So, I figured the radiator was a little low, so I filled it up to the bottom of the filler neck. Drove it to town and back, now the darn thing is back down right where it was! I'm assuming that I overfilled it and it keeps it at this level?
Thanks in advance
Old Nov 15, 2007 | 08:49 PM
colsoncj's Avatar
That seems odd... from my experience, usually the radiator stays full to the brim (or very close) and the overflow stays put or decreases over a large period of time due to evaporation and the like. Did the overflow increase in level when the radiator decreased? If not I'd say you have a leak which is causing the slight loss of fluid... If it is increasing (the overflow) I would fathom a guess that you might have the wrong radiator cap on (too low of PSI rating) which is allowing bleedback to the overflow.
Old Nov 15, 2007 | 08:51 PM
rowdy235's Avatar
yea i did notice an increase in the overflow tank. It does have an aftermarket cap, I think 12psi.
Old Nov 15, 2007 | 08:57 PM
Tofer's Avatar
Sponsor
my 81 does the same thing. sounds about normal
Old Nov 15, 2007 | 09:04 PM
colsoncj's Avatar
well its good to know its not vanishing into thin air.
The haynes manual states the range to be 10.7-14.9 and Oreillys (parts store) shows a 13lb as the replacement. Another thought is the cap isnt getting a good seal to the radiator letting some leak by...
Id check the seal on the cap, mating surface for the seal on the radiator, and condition of spring in the cap.
Old Nov 15, 2007 | 09:05 PM
colsoncj's Avatar
maybe its normal
jasonty
41
Dec 23, 2018 01:00 PM
82yodahickman
34
May 16, 2017 01:00 PM
Shagool22
Aug 14, 2015 12:24 AM
58rennur4
Aug 4, 2015 08:49 AM
JefferDean
Jul 31, 2015 10:39 AM
