Sponsored by: CARiD
Switching to 4wd fixes idle?
Old Dec 5, 2007 | 01:28 PM
KegKiller's Avatar
I've been having that stupid looping idle for awhile now, took it to the dealer and they said it it was the aux air valve, so i swapped in another. No difference, so I went to the wreckers and bought another throttle body, no difference. I check both TPS and they both read fine. We got about a foot of snow the past couple days so I engaged the 4wd to goto class. And for the 1st time in ahwile shes purring like a kitten again. What gives?
Old Dec 5, 2007 | 01:38 PM
Tacoclimber's Avatar
Your truck is telling you that she wants to be in 4wd ALL the time.
Old Dec 6, 2007 | 04:41 AM
GSGALLANT's Avatar
I'm not sure what the specifics of your truck are, but if you have vacuum actuated ADD, maybe you have a vacuum leak on the line that pulls you out of 4x4.
Old Dec 7, 2007 | 10:19 AM
KegKiller's Avatar
22re, 5spd, manual hubs
Old Dec 7, 2007 | 10:23 AM
swaycleveland's Avatar
kegkiller just had a similar problem kept surgeing high and low turned out to be a vac line but heres the thing i had to reset the puter a couple of times before it caught on the the line was pulged in again so with that said take a can of carb cleaner and spray the vac lines to see if it surges theres you leak next fix it and take the bat cables off may take a couple times to reset but it worked for me
Old Dec 7, 2007 | 02:17 PM
idayota's Avatar
vacuum leak. find it, fix it, reset the computer, and drive in 4wd as often as possible!
Old Dec 7, 2007 | 02:58 PM
fillsrunner4's Avatar
x2 with vacume leak
Old Dec 8, 2007 | 06:59 AM
KegKiller's Avatar
alright thanks guys, I'll go give'r a shot right now
Old Dec 8, 2007 | 09:20 PM
Shoua's Avatar
My truck's specs are the same, and that same thing happens to me too. I've also replaced all my top-of-the-engine vacuum lines with silicone hoses, yet it still does it sometimes.
Old Dec 8, 2007 | 10:37 PM
Matt16's Avatar
I have the loping idle (22RE) when I am idling with my foot on the brake or when I am idle and at full lock (and the power steering pump is still pumping). The idle is normal when I push in the clutch and the brake is off.
Old Dec 8, 2007 | 10:43 PM
Dare44's Avatar
^ Matt i got that same problem, i know its a vacume line i am just to lazy to try to find the leak
Eggslinger
Jun 8, 2019 03:32 PM
mskalmus
May 28, 2017 07:51 AM
Johntom240
7
Jul 13, 2015 12:18 AM
TokyoD23
Jul 12, 2015 06:01 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
