Sponsored by: CARiD
Loss of Engine Electronics
Old Dec 28, 2007 | 05:38 AM
Hoo Gnu's Avatar
This past summer, I had been running a 88 4runner v6 manual at 50 mph for 10 miles. Air temp 70F. I pulled in to the grocery for about 10 min. Car started right up, but when trying to get out of the lot, I had to wait for a car making repeated attemts to insert itself into a parking spot. About 60 sec. idling in neutral.
Then the engine abruptly died. When I turned the key...nothing.
I was on a slight slope, so I was able to coast backwards into a parking spot, where I tried the key again, and it started, (time since stalling, about 20 sec) and has not done to me again.
In spite of this, I don't really trust this car now.
Does someone out there know what would take both spark and starting circuits out?
I wish I could tell you about engine temp, but that gauge doesn't work.
Thanks.
Old Dec 28, 2007 | 01:45 PM
Paul H.'s Avatar
Check all of your connections like battery, alternator, starter and your grounds. Something may be loose or your alternator is going bad.
Old Dec 29, 2007 | 06:49 AM
FredTJ's Avatar
Originally Posted by Hoo Gnu
<SNIP>
Thanks.
Why would you think that the "spark circuit" went out ?
From your description it sounds as though it simply wouldn't turn over when you tried to start it.
That means there was, most likely, a problem with the battery and/or starter, either the parts themselves and/or the wiring to them.
If it's the battery then the alternator could be involved also.
Fred
Old Dec 29, 2007 | 08:00 AM
neoworm0's Avatar
I've been having a similar problem. Keep an eye on this thread,
https://www.yotatech.com/forums/f116...ing-up-130456/
I would start by checking the VAFM.
Does it sputter or run rough before it dies or does it just instantly shut off?
Old Dec 29, 2007 | 08:02 AM
neoworm0's Avatar
Does it stutter or run rough before it dies or does it just instantly shut off?
Old Dec 30, 2007 | 03:15 AM
Hoo Gnu's Avatar
FredTJ; The engine died when idling.
Neoworm0; Thanks for the link. When the engine died, it did not sputter. One second it was purring contendedly, then dead.
Old Dec 30, 2007 | 07:47 AM
neoworm0's Avatar
Try checking your EFI relay and COR relay. Seems to be what was happening with mine.
bigjstang
Jun 2, 2025 03:56 PM
Sleaker
Aug 26, 2020 06:03 AM
rushw
Jul 18, 2015 01:46 PM
msane99
Jul 11, 2015 08:08 PM
karbin
Jul 5, 2015 11:37 PM
