Sponsored by: CARiD
How to remove Gauge Cluster
Old Dec 29, 2007 | 09:16 PM
81redbluffyota's Avatar
From: I live in Red Bluff ca. Right by the Sacramento river
I need to swap in a new cluster apperntly, because my tach and fuel gauge got fried, in an overcharging episode. Its no problem as I have found one at my junkyard for 25 bucks, and theyre throwing in a bench seat also. I took the cover for the dash off, and removed the 4 screws to the cluster. It moves from side to side, up and down, but it doesnt pull out. I know theres plugs in it, but I look up and it looks as though they have some slack, so why doesnt it come out. Do I really have to weasel my hands in there and pull the plugs out? If so, they arent the snap on ones are they? God that will be a pain. Thanks.
Old Dec 29, 2007 | 09:27 PM
linuxrunner's Avatar
in my 88 there are 2 (maybe 3) plugs that hava all the wires, they are the push button type where you have to press a little tab to pull them out. Although on mine there was about 6in of slack in the wires.
The tricky part is getting the spedo cable off and on. Mine was a very tight fit with no extra slack so you have to squish your hand back there to pull it off.
Old Dec 29, 2007 | 09:39 PM
So I just have to remove the speedo cable, and it should come out? Did yours not want to pull out either? Which one is speedo cable? I can prob figure it out.
Old Dec 30, 2007 | 09:53 AM
rowdy235's Avatar
mine didn't want to pull out when I had to replace the bulbs. The speedo cable is the big cable-type thing that goes through the firewall out of the back of the cluster, not wires.
mussy01
Dec 13, 2016 08:20 PM
gary4runner
Sep 24, 2015 12:53 AM
teknovls
Aug 9, 2015 12:37 AM
Esibnitsud
Jul 30, 2015 08:21 PM
