85 EFI runnin' rich ??? HELP!
my 85 2.4 EFI pick up is running real rich so many sensors...o2, tps, afw, which one should i check first or what else could be wrong! been having fuel issues, if it wasn't for 4crawler she'd still not start!
I disconnected neg batt terminal, ran codes again and got tps sensor and knock control sensor. trucks running pretty good but engine light on. tried to adjust tps with feeler gauges and multimeter seems correct. my stop screw was backed all the way out, adjusted it then readjusted idle, same problem runs good but codes for tps and ks???
Longbed 90
Oct 19, 2015 11:05 AM
