Sponsored by: CARiD
high beams won't turn on
Old Jan 6, 2008 | 08:21 PM
.tebO's Avatar
Question high beams won't turn on
hi i'm having light problems as well, i have a 88 4runner with the 22re 5 speed. and the problem i'm having is that the high beams won't turn on. at first i thought that it might have been the headlights, so i changed them for the HELLA halogen conversion lamp. which did increase visibility, but i still need the high beams when i go to baja or drive in the middle of no where. i changed the sockets also, thinking that they were to old and that that might be the problem. but still no high beams, any suggestions, or has anybody had the same problem and was able to fix it, please help
Old Jan 6, 2008 | 08:28 PM
4banger444's Avatar
Ya this happend to me they wouldnt turn on when i pushed it whichever way your supposed to when u want them on i cant remember which way that is but all my lights would turn off but if i did it the other way and held it they would be on and i ended up having to replace the dim switch
Old Jan 6, 2008 | 08:32 PM
.tebO's Avatar
i forgot to put this in, but when i switch the high beams on or flick them. either or, they won't turn on at all
Old Jan 6, 2008 | 08:39 PM
4banger444's Avatar
Do you get any lights when you do that?
Old Jan 6, 2008 | 08:41 PM
.tebO's Avatar
the head lights just turn off and i'm lefted in the dark lol
Old Jan 6, 2008 | 08:45 PM
4banger444's Avatar
Well sounds similair except when i flicked them on the highs were on. But i have no clue i just took it in to the local shop took them a few minutes to figure it out. but i wouldnt replace it without knowing for sure it was liek 90 bucks i think
Old Jan 6, 2008 | 08:47 PM
.tebO's Avatar
k thank, if someone else has any suggestions, please help lol
thanks 4banger444
Old Jan 6, 2008 | 08:48 PM
4banger444's Avatar
Sorry not much help
Old Jan 6, 2008 | 09:06 PM
rowdy235's Avatar
Give this a twirl
http://www.4crawler.com/4x4/CheapTri...eadlight_Combo
hope that helps
Old Jan 6, 2008 | 09:16 PM
.tebO's Avatar
Originally Posted by rowdy235
thanks i will give that a try tomorrow morning, it's kinda cold and wet outside, but i WILL try this. lol i want to see how "bright " are these HELLAs
Old Jan 6, 2008 | 09:18 PM
.tebO's Avatar
Any more ideas, btw, thanks rowdy235
Old Jan 6, 2008 | 11:12 PM
stormin94's Avatar
It's probably either the switch, or the relay.
Old Jan 10, 2008 | 10:49 AM
.tebO's Avatar
ok, thanks everybody. the problem has been fix. checked the whole wiring. everything had current. then i looked for the relay, found it. my dad is good with electrical things, but he was busy. cleaned it, and tapped it with a screwdriver and WOALAH!!! now they work, but and they are REALLY good lights. i got the HELLA conversion halogen lights. and i got people doing light switching because they are bright. best thing of all, they are street legal in all states.
Old Jan 10, 2008 | 11:02 AM
4x4YOTA's Avatar
Im having this same problem I did the conversion to and have no high beams what so ever...
Old Jan 10, 2008 | 03:40 PM
bigarms23's Avatar
it probably a loose connection in your steering colum or its your headlight switch itself check both
calderp
Jul 27, 2015 09:58 AM
luckypig44
Jul 19, 2015 11:25 AM
Hamonacracker
Jul 17, 2015 08:33 AM
ZONAYODA
Jul 13, 2015 07:17 PM
raiderhawks00
Jul 8, 2015 06:23 PM
