Sponsored by: CARiD
ohmeter
Old Dec 11, 2007 | 07:08 AM
sleaz22xx's Avatar
ohmeter
when using a multi meter to test my ignitor and coil what should i e setting the multimeter to? Ohmm? 200? 2k?
looking to find a reading betwenn .36 and .55
Old Dec 11, 2007 | 11:46 PM
stormin94's Avatar
Use a metal coat hanger, and see which ones zap ya the least if you're concerned about voltage.....
Old Dec 12, 2007 | 03:20 AM
GSGALLANT's Avatar
You always select the lowest range that spans the values you are looking for. Since you are looking for values of less than 1 ohm, you set it to ohm. For values larger than 1 ohm but less than 200 ohm, you would set it to 200. For values larger than 200 ohm but less than 2000 ohm, you would set it to 2K... make sense?
Old Dec 12, 2007 | 09:09 AM
4Crawler's Avatar
Yep, good tips above. I have some more on the web page below:
http://www.4crawler.com/4x4/CheapTri...oUseAnOhmMeter
Mad Hauser
Nov 25, 2014 02:08 PM
Truckwithoutaname
Jul 20, 2014 11:08 PM
rburn
May 1, 2013 12:09 PM
Browntown3
15
Nov 8, 2012 07:19 PM
OKIDOG
Oct 31, 2011 02:52 PM
