Sponsored by: CARiD
code 14 and 25?
Old Dec 10, 2007 | 05:48 AM
sleaz22xx's Avatar
Arrow code 14 and 25?
1994 4runner 3.0 a/t Last night during normal driving conditions my dash spit a CEL at me, checked the codes this morning by jumping the ei and tei terminals and watching the flash!, two codes stored, a code 14 and a code 25
code 14
GNITION SIGNAL--NO "IGF" SIGNAL TO ECU
--IGNITER/IGNITER CIRCUIT
--IGNITER AND IGNITION COIL/CIRCUIT
--ECU
code 25
AIR/FUEL RATIO LEAN INDICATOR--LEAN SIGNAL SENT TO ECU FROM O2 SENSOR
--INJECTOR FAULT(S)
--FUEL PRESSURE
--OXYGEN SENSOR
--AIRFLOW METER OR MAP SENSOR
--IGNITION
--ECU
The ony idea that i have is that a recentley adjusted my idle speed but a bit to low (idles about-6-700rpm) Could this cause me to go lean an throw a code 25? Can anybody tell me why o would throw both these codes at the same time, and also where i should start with my troubleshooting. any input is greatly appreciated. THANKS
Old Dec 10, 2007 | 06:53 AM
sleaz22xx's Avatar
After some trouble shooting im pretty sure that ive got in pinned down to the ignitor, but have read that this thing can test good but still be bad, have also read that when the Ignitor sends no signal to the ECM it will shut down the injector? this would cuase a code 25?? : lean??
ANY INPUT IS APPRECIATED
Old Dec 10, 2007 | 02:09 PM
sleaz22xx's Avatar
bumpbump
Old Jan 29, 2008 | 03:17 PM
ReneB64's Avatar
ignitor
Did you figure out if this was the problem?
Old Jan 30, 2008 | 04:12 AM
sleaz22xx's Avatar
I replaced the ignitor and coil and have not got a code since
Old Mar 27, 2008 | 07:43 PM
sleaz22xx's Avatar
so after sometime code free a code 25 jumped back at me again tonight, i am beginning to think that i may have a burnt valve due to the fact that im pretty sure i have a valve ticking(may be injector sticking). Can sombody please lead me in the right direction as to how to trouble shoot these two( sticking injector/burnt valve) thanks
Old Mar 28, 2008 | 06:24 AM
sleaz22xx's Avatar
up to the topv
moparbay
Oct 6, 2015 09:24 AM
bradahman
Oct 1, 2015 09:24 AM
charlie_fong
Sep 27, 2015 10:06 PM
Odin
Sep 26, 2015 06:56 PM
Draven023
Sep 26, 2015 12:41 PM
