Sponsored by: CARiD
Brake issue, something new???
Old Mar 31, 2011 | 12:00 PM
Junkers88's Avatar
Posted this here since I'm a "brake rookie".
Recently went through and checked everything. The pads/shoes are new, springs in the drums are clean and work fine, the adjusters have been serviced and (according to what I've read) the rears are adjusted properly since I'm getting 13 clicks on the e-brake when I set it, read here it is supposed to have between 12 and 17 clicks to be correct. Thought it was the LSPV rod (lift and all that) so I removed it and installed the LSPV adjuster that I bought from RMA. Ran the adjustment up so that the LSPV rod is as high as it will go, most braking to the rear as if it's got a heavy load, and went out to the gravel pit to check the adjustment.
10mph, slam on the brakes and the fronts lock up but the rears do not. On the street I can't even get the fronts to lock up. The truck still stops fine but not as quick as I'd like. The system has been bled, there are no leaks, plenty of fluid and the MC/reservoir are also fine, no leaks, no air leaks nothing.....
I'm at a loss at this point. Help??
Old Mar 31, 2011 | 12:32 PM
Outsane's Avatar
turn the rig on...
press the brakes.. and see if the pedal falls on its own..
if it falls to the floor your MC is bad..
or maybe your brake booster went out?
Old Mar 31, 2011 | 12:44 PM
Junkers88's Avatar
Originally Posted by Outsane
turn the rig on...
Good idea, just went and tried it and the pedal moves about 2" before getting firm. I can't push it to the floor no matter how hard I press it.
Old Mar 31, 2011 | 01:27 PM
Outsane's Avatar
doesn't seem so bad...
I had crappy brakes for a long time after replacing my rear drum pistons. I did about a gallon of brake bleeding and nothing helped until I swapped out my MC and bled it all over again.
Old Mar 31, 2011 | 01:58 PM
Junkers88's Avatar
Thanks for the help. I'll see about swapping the booster/MC with one from the pick n pull.
I'm slowly getting tired of fixing things on this rig.........
Old Mar 31, 2011 | 02:04 PM
Outsane's Avatar
Must be time to take the rig off road to rekindle your love
I was just guessing at brake booster..
Old Mar 31, 2011 | 02:12 PM
Junkers88's Avatar
Must be.... she's been street bound for the last month due to minor issues and it's driving me NUTS.
Old Mar 31, 2011 | 02:14 PM
justin_4runner's Avatar
when u bleed them did u have the rig running or off? i had a hell of a time tell i did a one man bleed kit and had it running, just bleed them in the right order as fsm says and pumped each one 3 times and then i had good brakes.
Old Mar 31, 2011 | 03:55 PM
BigBluePile's Avatar
Dude. Bigger tires. More wieght. um...duh?
ehhehe
Time for a booster upgrade and new V6 calipers up front! Or get REALLY crazy and get some disc brakes in the back!
jasonty
41
Dec 23, 2018 01:00 PM
fountain
Dec 31, 2015 06:08 AM
CanRunner
Jul 20, 2015 01:29 PM
Johntom240
7
Jul 13, 2015 12:18 AM
87turboPA
Jul 9, 2015 05:58 AM
