Sponsored by: CARiD
Advice on rear locker use
Old Mar 13, 2011 | 06:04 PM
kruegs's Avatar
So, I was able to pick up a 99 Limited from my parents a few weeks back. It is in terrific shape overall, however I had a few issues with the 4wd getting "stuck" engaged, and the multi mode button on the side of the shifter not working. 2 new switches on the actuator and one corrected loose wire later and all is well again.
So... my question is: The Rear locker was NEVER used by my parents in the 9+ years they owned the rig (they were the 2nd owners). I am not too optimistic that it will work at all.
When I find a suitable place to try it out (dirt preferably), does anyone have any advice on things to try? I have read I think about turning in slow circles to try and "coax" it into working along with lining things up correctly. My fear too is that if I push the button on the dash, it will get "stuck" just like the 4wd did initially.
Thanks in advance for any advice/help.
Old Mar 13, 2011 | 06:24 PM
IanB's Avatar
Just go for a drive on the dirt, engage the AWD button and try driving, then letting off the gas and coasting, see if you can get it to engage/disengage that way. Also driving in slow circles, or slowly swerving left and right could help it engage. The rear locker I believe will only engage if you have the truck in 4hi or 4low.
Also, it's really easy, and a really good idea to change the front/rear diff fluid and transfer case fluid. Some fresh fluid could help the 4x4 system loosen up and work properly as well.
Old Mar 13, 2011 | 06:28 PM
waskillywabbit's Avatar
Follow the owner's manual for engaging the locker.
You can use a 9V battery and jumper the pinout to engage locker.
Elocker motor cleaning procedure on a thread on TTORA.
:wabbit2:
Old Mar 13, 2011 | 06:50 PM
SpecialScottie's Avatar
If its stuck you can pull the motor off and engage it with a screwdriver
Jun 1, 2021 01:51 PM
jerusry
Oct 19, 2015 05:28 PM
Daneums
Aug 20, 2015 05:36 AM
Iceman4193
Jul 15, 2015 04:48 PM
toyoda8488
Jul 5, 2015 10:18 PM
