Sponsored by: CARiD
idler arm install write up?
Old Mar 19, 2011 | 04:20 PM
brock77's Avatar
need to replace mine...to pass inspection...anyone no of a how to video here or on youtube ...or some good info on doing this.....
Old Mar 19, 2011 | 04:37 PM
Sportsmanphil's Avatar
Unbolt it and bolt in a new one. You might have to hit area of the center link where it passes through with a hammer.
Its not hard.
Old Mar 20, 2011 | 11:44 AM
brock77's Avatar
so i replaced my idler arm....105 lbs torque on the top bolts......40 lbs on the catle nut...(4x4wire toyota idler arm maintenance)...
but the catel nut is up high enough that the coter pin is just about at the bottom of the nut......is this alright...?
Old Mar 21, 2011 | 04:13 AM
RustBucket's Avatar
Can you explain that more clearly? Are you worried the castle nut has advanced too far or not enough on the stud?
Old Mar 21, 2011 | 07:15 AM
2DoorRunner's Avatar
As long as the castle nut cant spin, then your golden.
TJWilly
Jul 31, 2015 02:05 PM
Esibnitsud
Jul 30, 2015 08:19 PM
kirkrunner
Jul 27, 2015 07:59 PM
crashburnoveride
Jul 10, 2015 06:39 AM
ptb12
Jul 5, 2015 01:49 PM
