Sponsored by: CARiD
Problem NEED HELP truck keeps dieing out
Old Mar 5, 2011 | 01:37 PM
guzzifreak750's Avatar
Hello All I am new to the forum but after many searches have not found what I need help with.
I just purchased a 1988 4-Runner. My First Toyota and am STOKED. After driving for a couple of weeks and putting about 500 miles on it it started to randomly die while driving (No check engine light) after reading some forums I was thinking it was the fuel filter clogged up. Just replaced it today Thank you for all your posts on how to change it out what a pain. I relocated the filter to the inside of the engine bay on the passenger side fender. changed the oil and bolted everything up. Started the car and it ran fine for about 25 sec and then acted like it was starved for fuel. Did the same thing time and time again.
Any Advice?
My 88 has a 22RE 4cyl 4 wheel drive
Old Mar 5, 2011 | 02:23 PM
4Crawler's Avatar
Might try this and see if there is any difference:
- http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
Old Mar 6, 2011 | 09:09 AM
Still having trouble
Tried all you posted and replaced the fuel pump NO DICE still running for a little and then cutting out. Any more suggestions.
Thanks
Old Mar 6, 2011 | 09:35 AM
4Crawler's Avatar
Did you leave the fuel pump test jumper in place while running? If not, try that. And when it dies, is there still power to the fuel pump?
Old Mar 6, 2011 | 10:31 AM
six6vetteguy's Avatar
Does it start right back up? Or does it start right away after dying?
Old Mar 6, 2011 | 01:46 PM
Junkers88's Avatar
Some basic things to check regard air in and air out. I know a bad/dirty air filter will cause this, so will a clogged cat although it has to be REALLY clogged up.
Old Mar 6, 2011 | 07:40 PM
to awnser posted questions
The cat has been gutted and welded back up that is not the prob. I will check the air filter in the AM but it has a K&N drop in but I will give it a clean and see what we got.
As far as starting. it dies out and I can start it right back up no prob then it dies again.
Thanks for helping will get this I know it.
Old Mar 7, 2011 | 04:43 PM
Thank you to all but Im a dumb ass
Thanks everyone that posted but I did the stupid thing and should have just checked over all of my connections before throwing parts at this thing.
I was messing with some of the stuff 4 crawler suggested and the ECM plug on top of the air box just fell out of place. As soon as I plugged it in correctly no problems. I felt like a dumb ass but fixed my problem.
Now though my temp gauge is not registering going to check the fuse's in the morning but its blowing heat any suggestions.
Thanks again to all.
91toybeater
Dec 27, 2015 07:46 PM
puffin04
Jul 10, 2015 09:17 PM
Alex Bessinger
Jun 28, 2015 10:05 AM
ibayne
Jun 26, 2015 06:30 AM
slider417
Jun 22, 2015 10:18 AM
