Sponsored by: CARiD
Choppy acceleration
Old Mar 18, 2011 | 12:23 PM
homesteader's Avatar
Choppy acceleration
I have an 86 4-runner with EFI that I had a ton o work done last Summer including the following
oil change
F/R/brakes rotors, pad, etc.
Plugs
dist cap
new fancy muffler put on
She is running alright, but when accelerating it is really choppy sort of like a misfire, but it is not backfiring. It does not happen when idling, only when pressing on the gas initially. After engaging the pedal a fair bit, it goes away. Speed does not matter, as it happens in 1st or fifth if I let of the pedal. I have no idea where to start and the shop I took it to, said whatever even though I spent over 2K there and ask them to find everything wrong with it. This was not occuring before I took her to the shop.
Ideas on where to look would be greatly appreciated,
Devin
Old Mar 18, 2011 | 12:36 PM
James Woods's Avatar
You said plugs and dist cap, but what about wires, rotor and fuel filter?
Old Mar 18, 2011 | 12:37 PM
Sorry, wires, and I believe rotors were done also. FF was not, as I have not had time to drain the system, which I thought was required.
Old Mar 18, 2011 | 12:45 PM
Drian the fuel system? You dont have to do that, the fuel filter is on the engine block not in the tank. Its under the intake manifold on the passenger side of the engine, you can see it by looking through the passenger wheel well area.
Old Mar 18, 2011 | 01:05 PM
I will have to look at the manual again, but there something dealing with fuel that I was not ready to deal with at that time IIRC.
Old Mar 18, 2011 | 01:08 PM
Also, check to see if there is any codes in the computer.
Old Mar 18, 2011 | 01:11 PM
I am new to this, other than oil changes and plugs, so what is recommended to read the codes?
Old Mar 18, 2011 | 01:15 PM
badattitude's Avatar
Some autoparts stores will read your codes at no cost. Call a couple and ask if they will read your codes. They should ask what year your truck is so they have the right code reader.
Old Mar 18, 2011 | 01:25 PM
Its an 86 so an auto parts store probably wont be able to do it
https://www.yotatech.com/forums/f116...-codes-220985/
will show you how to do it, also download the FSM for your truck, it will help a lot.
https://www.yotatech.com/forums/f120...s-info-175794/
Old Mar 18, 2011 | 01:34 PM
blake.nemitz's Avatar
get a paper clip and short e1 and te1 termonals in the diagnostic port and see if you read a code off you cel
Old Sep 2, 2012 | 10:48 AM
lilyota1's Avatar
I have that exact same issue
shooter86314
Jan 7, 2016 07:05 AM
calderp
Nov 16, 2015 02:49 AM
Flightguy
Oct 2, 2015 05:34 PM
Ott47
Sep 14, 2015 12:09 PM
Boomer8404
Sep 10, 2015 09:01 AM
