Sponsored by: CARiD
95 taco bucking / missing under load
Old Mar 7, 2011 | 08:55 PM
deeyota's Avatar
Hello all, yes I searched but I don't feel any result is my exact problem...95 taco v6 5 spd 4x4, leveling kit and add a leaf, other than that bone stock. problem is when under load ( lower rpms ) usually in second sometimes 3rd and rarely 4th it bucks as I increase gas, or hesitates, like if its something electric, no loud bangs but its a fairly violent skip. When I'm higher, say above 4k rpm its smooth as can be, no slipping, any gear. This has been a progressively worsening problem and I need some solid advice before I start buying parts.
I've read everything in searches, MAF, tps, warped flywheel, clutch,coils etc. If I need to be more specific I can. I had some issues with my 89 4runner and yotatech always helped. where do I start ?!
Old Mar 7, 2011 | 08:57 PM
deeyota's Avatar
Replaced plugs n wires after problem started, no better.....
Old Mar 7, 2011 | 09:29 PM
James Woods's Avatar
also cap and rotor? Any codes?
Old Mar 8, 2011 | 07:51 AM
deeyota's Avatar
No cap, or rotor, I have the 3.4 and it has the three coils which were not replaced. No codes / cel
Old Mar 8, 2011 | 11:09 AM
deeyota's Avatar
Visual check done today, every thing " looks " good. Notice that when cold and warming up, idle seems to fluctuate in the slightest amount until warm. I'm thinking coil packs.... but still waiting on some feedback. Any help is appreciated !
Old Mar 8, 2011 | 11:49 AM
deeyota's Avatar
It also seems to "break up " slightly on throttle from 1.5k - 4.5k rpm... in neutral, warm and cold
Old Mar 8, 2011 | 01:02 PM
toyota hunter 07's Avatar
Same problem w/my 94 3.0 only when its cold???....
Old Mar 8, 2011 | 03:35 PM
deeyota's Avatar
Anybody ? Maybe this is in the wrong forum....
Old Mar 8, 2011 | 03:46 PM
I was thinking maybe the cold start injector was pulsing as it cuts out when the truck warms up...cause then it goes away...for me its only when i jump in cold in the morning and when i let the truck warm up it dosnt do it ....thats why im leaning towards the cold start injector ....what i may do is when its cold un plug the injector start the truck and drive right away and see if it happens.....
Old Mar 8, 2011 | 03:56 PM
deeyota's Avatar
In my case, it is hot and cold
Old Mar 8, 2011 | 04:18 PM
survivorman97's Avatar
i think you are on the right track with the coil packs
Old Mar 8, 2011 | 05:32 PM
rworegon's Avatar
Vacuum leak? Check for dry rotted hoses, cracks in flexible intake tube, around the throttle body, etc. Could a plugged PCV play into this?
Old Mar 8, 2011 | 07:45 PM
peow130's Avatar
o2 sensor?
ect sensor?
exhaust leak?
Check codes at your local schucks?
Old Mar 9, 2011 | 07:21 AM
deeyota's Avatar
Originally Posted by peow130
o2 sensor?
ect sensor?
exhaust leak?
I do have a small exhaust leak... but there is no way you will convince me that's what wrong
Old Mar 9, 2011 | 08:28 AM
That all depends on where the exhaust leak is, if it is before the O2 sensor, then that can mess up all kinds of things as the ECU isnt getting the proper readouts of the exhaust.
Old Mar 9, 2011 | 10:46 AM
deeyota's Avatar
It seems to be at the brackets off the header, so yes it is before the o2 , maybe I will start there.
crammit442
7
Nov 29, 2017 12:30 PM
rodskwad
Aug 12, 2015 02:33 AM
rap2me
Aug 11, 2015 05:03 PM
Crgrey42
Aug 10, 2015 04:23 AM
Luvmeye22re
Aug 4, 2015 03:53 PM
