Sponsored by: CARiD
22re to 22r swap?
Old Mar 3, 2011 | 03:30 PM
Dufek125's Avatar
22re to 22r swap?
So my daily driver 87 4runner started making a horrendous knocking noise from the engine with serious power loss. So i found a cheap motor on craigslist to swap in for the time being. only problem is that it is a 89 22r and my truck stock is a 87 22re. I know that the blocks are everything else is basically identical but are there any unknowns I will have to factor for other than just swapping the EFI components over to the new engine? The ECU and fuel pump, etc is already there. Would it be easier to just swap in the 22r and keep it carbed?
Old Mar 4, 2011 | 01:43 AM
toyota4x4907's Avatar
It would actually probably be easier to keep it EFI. '89 22r, so it must be from a 2wd. The oil pan and pick-up tube will be different, so you'll need to put your 4wd one on. Basically all you'll need is the block and head from the '89. Everything will be bolt-on.
Old Mar 4, 2011 | 04:47 AM
irab88's Avatar
easier to keep the efi, possible to just convert it to carb'd. i was thinking about it to convert to propane, but found a kit that i didn't need to.
from this post on:
https://www.yotatech.com/forums/f199...l#post51671880
Old Mar 4, 2011 | 09:52 AM
Dufek125's Avatar
yea its from a 2wd, what do you mean by the pick up tube? im moreworried about the vaccum hoses and getting something hooked up backwards.
Old Mar 9, 2011 | 10:50 AM
Dufek125's Avatar
well good news, got everything swapped over and its back in the truck, now to just get everything hooked back up and hit the trails.
sandyota
Feb 4, 2021 11:16 AM
mskalmus
May 28, 2017 07:51 AM
deepmarsh
Aug 6, 2015 03:44 AM
cars-guy
Jul 11, 2015 07:51 PM
Tyler Cunningham
Jul 11, 2015 10:18 AM
