Sponsored by: CARiD
New member with motor problems!
Old Mar 29, 2011 | 11:11 AM
poof's Avatar
Ok guys my name is Aaron. i have an 87 sr5 runner. love it. i replaced the head over this winter. i went to try to start it and it will try to fire, but then after a couple attempt it backfires threw the intake. it actually blows the intake off the filter box!!!!! I think its a timing issue. But i didn't change the position of the timing chain. Any ideas???? Im trying to avoid taking the head back off.
Old Mar 29, 2011 | 11:32 AM
justin_4runner's Avatar
have u check to make sure all your timing marks are lined up? sounds like u have distributor 180 out. set motor at tdc number one and see it is pointing that the correct spot in the cap.
Old Mar 29, 2011 | 10:32 PM
the_supernerd's Avatar
I agree that the ignition timing could be 180* off. Also double check the firing order and make sure that none of the valves are too tight. I would think an intake valve that is not closing could cause a bad backfire like that.
Old Mar 30, 2011 | 09:25 PM
poof's Avatar
i thought it was 180 out also. But i have checked this, and the timing chain, and see if it is at tdc. and it all checks out. it acts like the firing order is off. 1,4,3,2 i think is what the book said. idk. i almost want to pull the timing chain and see if it was installed wrong the last time it was done.
Old Mar 30, 2011 | 10:09 PM
toyotabull's Avatar
Try 1-3-4-2 It will run better, but if that doesnt completely work, try turning the distributor 180
Old Mar 31, 2011 | 02:28 PM
I agree, firing order is 1-3-4-2.
jerusry
Oct 19, 2015 05:28 PM
Sep 4, 2015 09:27 AM
AaronM
Jul 8, 2015 07:15 PM
karbin
Jul 5, 2015 11:37 PM
