Sponsored by: CARiD
engine swap years to avoid?
Old Mar 5, 2011 | 07:47 AM
jvbutter's Avatar
yesterday I pulled the engine apart on the Runner... boy did i get a chop job... I bought this last month as a project. anyway previous owner did quite a few bonuses for me... He had "rebuilt / resealed" what ever and fixed it good. So after what i see he did, I will either need a new 3.0 engine. Or swap into the 3400. I will go out today and look at a few in the local area... anything to watch out for... any particular years for 3400 that are better or worse when doing the swap??? I have an auto in the Runner now. Id like to keep it. Here is one of many fine techniques he used... there should be a bolt head on top of that washer... Yes he welded the washer to what was left of the bolt he twisted off
Old Mar 5, 2011 | 08:39 AM
crolison's Avatar
95.5-96 3.4 had some head gasket issues, but nothing like the 3.0
Old Mar 5, 2011 | 09:00 AM
jakestolar's Avatar
Previous owner is obviously an ASE Certified PRO!!!
Old Mar 5, 2011 | 09:56 AM
jvbutter's Avatar
crolison: thanks I will watch for it...
jake... yea there was other things also... vac line not laying nicely as if they didn't belong on that port... prolly 1 of 4 bolts loose... like finger tight... exhaust manifold bolts stripped... I wonder if the head bolts are even tight, causing the gasket issue... amazing all that time into the engine, to leave things loose.
Old Mar 5, 2011 | 03:12 PM
dntsdad's Avatar
http://board.marlincrawler.com/index.php?topic=78631.0
Old Mar 6, 2011 | 07:25 AM
jvbutter's Avatar
thx for the link... there is actually a 3400 here locally to me. St George is a bit of a drive... nice road trip.
Old Mar 6, 2011 | 10:00 AM
mt_goat's Avatar
Lots of info in the engine swap sections: https://www.yotatech.com/forums/f159/
Good luck
Old Mar 6, 2011 | 02:06 PM
jvbutter's Avatar
thx mt. goat for chiming in... Ive been reading some of your comments in older posts... like 2yr old posts... My big hangup comes in pricing and return. I have done a few eng swaps... threes more cost than just the engine and tranny price... its more of the extras that get you in the cost. I'm debating on just dropping in an older (top end rebuilt 20k miles ago) or just dropping in 3400. Not to sure on keeping this runner. I will keep it through summer for sure. From all the reading it seems it can be done pretty cheap... reuse oil pan new hoses and belts, what ever maint items you want to change while its out. Oh this new engine has 80k on it... the guy was going to do the conversion, so he has done the dipstick swap and has new oil pan
Old Mar 6, 2011 | 03:31 PM
RobD's Avatar
I went with a 97 Tacoma engine. Worked out well in terms of the swap.
Old Mar 6, 2011 | 05:32 PM
jvbutter's Avatar
Rod... Do you have auto or manual???? and did u use the stock unit, or the 97 tranny???
Old Mar 6, 2011 | 08:07 PM
RobD's Avatar
I have a 5 speed. Bolts right up. I used the flywheel, clutch, and pressure plate from the 3.4 and the throwout bearing from the 3.0.
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
puffin04
Jul 10, 2015 09:17 PM
noahstancik
Jul 10, 2015 11:18 AM
Alex Bessinger
Jun 28, 2015 10:05 AM
TheManOutside
Jun 18, 2015 03:32 PM
