89-95 2wd Pickup fabtech lift and coilovers
im new here and been searching till my eyes cant see any more and have not found anyone that has done this. im starting to wonder if its even possible.
can you use coilover shocks instead of torsion bars with the fabtech 3.5 uca for the 89-95 toyota 2wd's. and will it effects the suspension durability if you dont triangulate the lca's.
this is the lift he is talking about or at least it should be, and no on the coilover without more fabwork on the UCA.
http://www.fabtechmotorsports.com/pr...y=TOYOTA%202WD
Not sure if this means anything but....
*FOOTNOTE
1. Larger tires can not be installed on OEM wheels.
2. Use w/ sway-away 1636 torsion bars.
3. Some models may sit low in rear.
*FOOTNOTE
skoti89
07-06-2015 07:45 PM
Vargntucson
07-04-2015 12:15 PM
