Sponsored by: CARiD
semi newb question 22re
Old Mar 6, 2011 | 06:07 AM
bmaurice's Avatar
Im replaceing my 150k 22re"typical BHG due to loose chain" with a slightly newer 22re. just want to know if im forgetting any parts i should replace for better luck of a bright future.
Ignition
dist,cap,rotor,plugs,wires.
EFI
clean upper, lower,and throttle body, fuel injectors serviced.
block
timingchain,water pump, oil pump,thermostat,oil pressure sensor
clutch,new balancer, regrind flywheel.
Old Mar 6, 2011 | 06:10 AM
Bojangles's Avatar
Go ahead and do the oxygen sensor.
after 150,000 miles, it cant do anything but help.
Get the OEM plug in, not the universal.
Old Mar 6, 2011 | 06:31 AM
bmaurice's Avatar
looking at them now do i want before or after cat sensor. prices vary like razy anywhere from 30-90 dollars. Bosch any good?
coleypull15
Nov 3, 2015 07:41 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
colasurdo
Jul 16, 2015 11:32 AM
icentropy
Jul 14, 2015 10:23 AM
icentropy
Jul 9, 2015 02:12 PM
