Sponsored by: CARiD
what happens when you step on gas?
Old Mar 13, 2011 | 05:14 PM
SDHNTR's Avatar
I know it seems like a dumb question, but what exactly happens when you step on the gas pedal? I always though that doing so squirted more gas into the engine. A gearhead friend of mine said that on a 22re, when you step on the gas it actually lets more air in, not fuel. Is this true?
Old Mar 13, 2011 | 05:33 PM
rustypigeon's Avatar
When you step on the gas, you open the throttle plate, which allows more airflow. This airflow increase is sensed by the Volume Airflow Meter, which tells the ECM to squirt more fuel through the injectors. The amount of fuel going through the injectors is adjusted by changing the length of time that the injectors are open.
toyota4x4907's Avatar
Yes. When you step on the gas pedal, it opens the throttle plate more, allowing more air in, which the ECU reads through various sensors, then, determining how much fuel is needed per the amount of air flowing in and out of the engine, it increases or decreases the rate at which the injectors open to allow fuel in.
Old Mar 13, 2011 | 05:49 PM
toyotanick's Avatar
very nicely put guys!
Old Mar 13, 2011 | 06:13 PM
iamsuperbleeder's Avatar
you go faster
just what they said
Old Mar 13, 2011 | 06:26 PM
rworegon's Avatar
My gas mileage goes down, but the posts above are descriptive.
Blamalam
Mar 12, 2022 07:34 AM
Eggslinger
Jun 8, 2019 03:32 PM
rushw
Jul 18, 2015 01:46 PM
smiley52
Jul 11, 2015 05:16 AM
