Sponsored by: CARiD
Exhaust hitting shock
Old Jun 23, 2014 | 08:45 PM
Satanssidekick's Avatar
I have a 82 truck and when I replaced my shocks I noticed the exhaust had melted the rubber shock boot. I'm not sure if there is supposed to be a heat shield or if my exhaust is ran wrong. Any info is appreciated.
Old Jun 24, 2014 | 09:10 AM
highonpottery's Avatar
too many variables to give straight answer, pics would help significantly. very likely that someone's changed something on your truck over the past 30yrs - or the exhaust may have shifted because it was hit/bent or the rubber hangers are worn or the less likely, someone changed your shock mounts without redoing the exhaust. i would first look at the exhaust and see if you can slightly move it over by bending your exhaust hanger brackets. there are no heat shields between the exhaust and shocks. if all fails, i'd say change up the exhaust and possibly upgrade it for a little more seat of the pants power gain.
good luck and welcome to YT!
Old Jun 24, 2014 | 01:06 PM
wyoming9's Avatar
Red face
You should be able to pull your exhaust away from the shock then factory shocks never had boots
Blamalam
Mar 12, 2022 07:34 AM
punks_is_4x4
Aug 21, 2015 01:35 PM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
defrag4
Jul 31, 2015 10:50 AM
Dakotaneu
Jul 27, 2015 12:03 AM
