Sponsored by: CARiD
Help- 87 22R starting issues
Old Aug 12, 2014 | 12:54 PM
Corbin8431's Avatar
I got a 87 22r pick up. I'm having problems starting it all it does is click I bought a new starter and still just a click I can pop start it and I have tested everything and am Geting power. Idk what the hell it could be
Old Aug 12, 2014 | 03:36 PM
dropzone's Avatar
Fossilized
check your connections, cables and grounds
i fixed your thread title..."help" by itself can lead to your thread being deleted..
Old Aug 12, 2014 | 03:40 PM
abecedarian's Avatar
+1 on connections.
Also, could be a defective ignition switch not sending voltage to the starter solenoid properly. Make sure you're getting 12v to the smaller wire connected to the starter- if no voltage when the key is turned, the ignition switch is probably at fault. If you are getting voltage there, try jumping 12v directly to the smaller terminal on the starter. If this fixes it, you should be able to get by with installing a relay inline between the key switch and the starter.
Jmiller1023
23
Aug 6, 2015 07:03 PM
thelifeadventure
Jul 2, 2015 03:09 PM
Alex Bessinger
Jun 28, 2015 10:05 AM
slider417
Jun 22, 2015 10:18 AM
jmc88runner
Jun 18, 2015 03:39 PM
