Sponsored by: CARiD
95 4 runner bucking?
Old Jun 18, 2014 | 05:51 PM
Cateduran86's Avatar
I have a 95 4runner v6 4wheel drive. It's been bucking mostly at freeway speeds for a couple months now. Took it to a mechanic who replaced the ignition coil and thought if fix it. It didn't. A couple weeks ago I was on the freeway when the truck stopped accelerating. The rpms and speedometer when to 0 but the engine stayed on. Once I got to the side I tired it off and it wouldn't start again. Took it to the Same mechanic fiddled and then figured out it was the ignition coil. It now starts and drives again but it smells like gass when I start it and it's still bucking. Could it be an issue with the fuel system?
Old Jun 18, 2014 | 05:57 PM
rworegon's Avatar
Is the check engine light coming on? Are the connections at the battery and ground wires clean and attached?
Old Jun 18, 2014 | 09:09 PM
vital22re's Avatar
totally a bro
Dare I say it, but you've got a hard miss going. Pull the plugs out and look at the condition of them.
Old Jun 19, 2014 | 07:16 AM
thefishguy77's Avatar
Check the plugs and check to see if your throwing any codes.
Old Jun 19, 2014 | 01:03 PM
No lights coming on when it's bucking. The battery's got some gunk I could try that. Thanks for the advice I'll see what I can find. I'm pretty new at this
Old Jun 19, 2014 | 01:06 PM
I'll pull me out and look. It idles ruff also, same issue? Thanks
Whatever123
Sep 30, 2015 12:12 AM
MTLroadierunner
Jul 15, 2015 12:58 PM
mickyd9990
Jul 6, 2015 09:01 AM
wilbertd
Jul 6, 2015 07:39 AM
