Sponsored by: CARiD
4 speed transmission
Old Jul 26, 2014 | 06:12 AM
Bruinpilot's Avatar
I have an 89 2x4 with the 22r motor and a 4 speed transmission. A coworker recently old me that he had the same and that a transmission shop put a 5th gear in his transmission for him. I said surely they just swapped it out for a 5 speed. He was adamant that they did not swap trannys but just put in the extra gear. Is this possible? And if so, is it something that a shade tree mechanic like me might be able to do? Thanks
Old Jul 26, 2014 | 06:40 AM
CJM's Avatar
CJM
Your coworker is a moron. There are aftermarket overdrive units you can buy that can be put on some vehicles, but it takes alot of work.
Old Jul 26, 2014 | 12:20 PM
Robert m's Avatar
They did a 5spd swap which is common and pretty easy to do
Old Jul 26, 2014 | 04:55 PM
wyoming9's Avatar
Red face
Sure it could be done but the cost would be quite expensive.
We are talking in the case and not a bolt on after drive unit.
Then you would need to turn shafts cut gears .
More or less build a transmission to fit in the case you have.
While some shade tree mechanics might be equipped to do this things most have moved into a shed by this time.
I would also have to go with the 5 speed swap If your friend did not do the work they most likely don`t know what was done.
Old Jul 27, 2014 | 12:04 AM
Terrys87's Avatar
Even if it could be done, tearing a transmission down is not easy for the shade tree mechanic. I swapped in an 83 Celica transmission into an 87 that was a 5 speed when my 87 was a 4 speed and it was a direct swap. No changing driveshafts, tranny mounts, or speedometer gear. Another option that you could look into.
Old Jul 28, 2014 | 08:48 AM
Bruinpilot's Avatar
I'm getting a little over 28 mpg with mostly highway driving on my 4 speed. I wonder what kind of a difference the 5 speed would make...
Liadrin
Apr 25, 2022 02:54 PM
BeMiceElf
Oct 10, 2015 09:40 PM
Liadrin
Sep 1, 2015 06:44 AM
HollieJayyy
Aug 9, 2015 07:59 AM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
