Sponsored by: CARiD
After headjob no power to starter
Old May 20, 2014 | 11:59 AM
camrycamper's Avatar
Just finishing up a head gasket replace on '92 22RE FI pickup.
Pressing the clutch in gives a relay click from the glove box area but no starter solenoid energize. Have I forgotten something?
Fresh battery, clean terminals, ground tight behind compressor, solenoid wire still attached to solenoid.....
Old May 20, 2014 | 12:57 PM
RAD4Runner's Avatar
See starting/ranking system explained on my build thread. It's for 86-88 4Runner but should be similar to yours.
Got a multi-meter? if not Harbor Freight is your friend.
keep us posted.
Old May 20, 2014 | 04:09 PM
I almost sure this is a re-assembly issue since it was doing fine previously.
Safety Interlock?
Harness plug on plenum?
Seat switch?
Old May 20, 2014 | 04:17 PM
RAD4Runner's Avatar
Safety Interlock?
Seat switch?
The only safety interlock I know is the clutch switch.
What harness plug on the plenum?
What seat switch?
What exotic 4Runner do you have?
Did you look at starting system to see what it takes to make starter solenoid click?
Anything else working?
Let me reiterate...
Old May 20, 2014 | 06:07 PM
INFINITY's Avatar
run a jumper wire with a spade from the starter motor (where the small wire attaches to the solenoid on the starter) and turn the ign to on and tough the jumper wire (that is attached to the spade connector you put on the starter) to the bat +. this will turn on the starter and as soon as you disconnect the wire from the batt + it will stop the starter motor.
if this works than you have a corroded wire to the starter soloniod (usually it is the first 5" of the wire attached to the starter) or your clutch cancel/nss wire is messed up.
so basically your ign switch is not making + from the batt through the keyed switch through the safety switch to engage the starter.
good luck
Old May 21, 2014 | 12:23 AM
wyoming9's Avatar
Red face
You can lead them only so far!!!
Old May 21, 2014 | 03:25 AM
Now that was easy to read...
The ground is wet with the "chocolate milk" that came out of the pan.
It's good to tell me "spade terminal" so I only have to stay under it shortly. I was going to use an alligator clip to jump it.
I understand clutch safety switch.
Please, what is cancel/nss ?
Old May 22, 2014 | 07:31 AM
thefishguy77's Avatar
I believe the clutch cancel switch is the button of the left hand side of your dash. That you depress to start the truck without pressing the clutch. Now that I have opened my mouth I'm probably wrong. Good luck
Old May 22, 2014 | 05:23 PM
jimbyjimb's Avatar
Do you have a ground wire from the firewall to the driver's rear side of the head?
Old May 22, 2014 | 05:35 PM
INFINITY's Avatar
nss= for an auto, neutral safety switch
Old May 22, 2014 | 08:50 PM
vital22re's Avatar
totally a bro
You need a measurement of the voltage to the starter signal wire to the solenoid. If its less then 10v it will struggle to start/not start.
Old May 25, 2014 | 07:20 AM
Erick561's Avatar
From: I ship from New London Connecticut I PriceMatch
This will cause a lot of problems (EG frying a $400 stereo system... :homer
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
clok
Aug 1, 2015 09:42 PM
ZONAYODA
Jul 13, 2015 07:17 PM
colinmil
Jul 6, 2015 04:03 PM
